hispeed 9 Posted February 2, 2019 Posted February 2, 2019 (edited) Hi, I recieve this when I search in the latest emby version. Last time I added my sources new. Should I do this once again? After this exception emby-server is down and need to be restarted. Information: CentOS 7 virtual Client: Huawai Mate 20 Pro (Emby latest) System.IO.IOException: System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.GetResult(Int16 token) at System.Net.FixedSizeReader.ReadPacketAsync(Stream transport, AsyncProtocolRequest request) at System.Net.Security.SslState.ThrowIfExceptional() at System.Net.Security.SslState.CheckThrow(Boolean authSuccessCheck, Boolean shutdownCheck) at System.Net.Security.SslState.CheckOldKeyDecryptedData(Memory`1 buffer) at System.Net.Security.SslState.HandleQueuedCallback(Object& queuedStateRequest) at System.Net.Security.SslState.FinishHandshakeRead(Int32 newState) at System.Net.Security.SslState.FinishHandshake(Exception e, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.RehandshakeCompleteCallback(IAsyncResult result) at System.Net.LazyAsyncResult.Complete(IntPtr userToken) at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken) at System.Net.AsyncProtocolRequest.CompleteUserWithError(Exception e) at System.Net.FixedSizeReader.ReadPacketAsync(Stream transport, AsyncProtocolRequest request) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) --- End of stack trace from previous location where exception was thrown --- at System.Threading.ThreadPoolWorkQueue.Dispatch() Source: System.Net.Sockets TargetSite: Void ThrowException(System.Net.Sockets.SocketError) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.GetResult(Int16 token) at System.Net.FixedSizeReader.ReadPacketAsync(Stream transport, AsyncProtocolRequest request) at System.Net.Security.SslState.ThrowIfExceptional() at System.Net.Security.SslState.CheckThrow(Boolean authSuccessCheck, Boolean shutdownCheck) at System.Net.Security.SslState.CheckOldKeyDecryptedData(Memory`1 buffer) at System.Net.Security.SslState.HandleQueuedCallback(Object& queuedStateRequest) at System.Net.Security.SslState.FinishHandshakeRead(Int32 newState) at System.Net.Security.SslState.FinishHandshake(Exception e, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.RehandshakeCompleteCallback(IAsyncResult result) at System.Net.LazyAsyncResult.Complete(IntPtr userToken) at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken) at System.Net.AsyncProtocolRequest.CompleteUserWithError(Exception e) at System.Net.FixedSizeReader.ReadPacketAsync(Stream transport, AsyncProtocolRequest request) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) --- End of stack trace from previous location where exception was thrown --- at System.Threading.ThreadPoolWorkQueue.Dispatch() InnerException: System.Net.Sockets.SocketException: Connection reset by peer Source: TargetSite: Thanks for any help. Marc Edited February 2, 2019 by hispeed
Luke 42221 Posted February 3, 2019 Posted February 3, 2019 Hi there, @@hispeed, please attach the complete emby server log. thanks !
hispeed 9 Posted February 3, 2019 Author Posted February 3, 2019 Hi Luke, https://privatebin.net/?4c0c09b951384028#zFrRxiE4Oc1lHOwb/wwnhlhyVOegELeH1tPRQzLKi8w= Password: luke2019 Delete: in 6 days from today It will take some time to open (decrypt) a few lines for you, I hope it's enough.
Luke 42221 Posted February 4, 2019 Posted February 4, 2019 @@hispeed can you please attach it to this forum post, or PM it to me? Thanks.
hispeed 9 Posted February 4, 2019 Author Posted February 4, 2019 Here we go Luke :=). Happy week start and take it easy. I bought also Premium Emby 2-3 weeks ago and I'm very happy, thanks for your help and your support. log_exception_emby.txt
Luke 42221 Posted February 4, 2019 Posted February 4, 2019 @@hispeed, where is the exception? This log looks pretty clean to me. There is only one error i see here and that is a malformed request from what appears to be EmbyCon. I can let the developer know but that has nothing to do with searching.
hispeed 9 Posted February 4, 2019 Author Posted February 4, 2019 Hi Luke, I sent to you both logs the first log in the first post shows the exception for me?
Luke 42221 Posted February 4, 2019 Posted February 4, 2019 Right but the first post is only a snippet. I would like to see the entire log file. Thanks.
hispeed 9 Posted February 4, 2019 Author Posted February 4, 2019 I'm sorry I don't have more in the log. I would have probably to activate the debug log.... As you can see, it's all I have in this log. So I probably need to activate the debug log and try to reproduce? 1
Happy2Play 9806 Posted February 4, 2019 Posted February 4, 2019 @@Luke Here the log from post 3, the exception is at the end of the log. Is this the OS issue with audiodb? log.txt
Luke 42221 Posted February 4, 2019 Posted February 4, 2019 Yes, sorry, my mistake. I missed it. @@hispeed, please see this topic for a solution: https://emby.media/community/index.php?/topic/69167-emby-server-4010-crashing-on-music-playback Thanks. 1
hispeed 9 Posted February 4, 2019 Author Posted February 4, 2019 (edited) Hi Happy2Play and Luke, I don't think it's because when I start playing music files it works. This error I recieve when I searching thru my movie database. So I type a word and delete (fast) not all result are showed and you rewrite the searching word. As mentioned I have the server on CentOS 7 and I used a new installation one year ago and this installation was without mono? <- This was the reason I made a new clean install. I don't understand that mono thing . here we go again with debugging level I can reproduce it. Client = Iphone 7 (emby lates app) Please look at the attachement. All ip are replaced with random ones internal / or external. Switzerland goes now to bed, cya tomorrow . emby_debug_reproduced_exception_search.txt Edited February 4, 2019 by hispeed
Luke 42221 Posted February 5, 2019 Posted February 5, 2019 Yes actually that looks like the reason. Please see that other thread. Thanks.
hispeed 9 Posted February 5, 2019 Author Posted February 5, 2019 Ok Thank you I will do that at the weekend and hopefully it work as well on my database .
Solution hispeed 9 Posted February 10, 2019 Author Solution Posted February 10, 2019 Hi Luke, For anyone who is reading this. Make a backup of your sqlite3 version and of your database before you read this. I did the following: systemctl stop emby-server sqlite3 --version Output: 3.7.17 2013-05-20 00:56:22 Visit: https://linuxhint.com/upgrade-to-latest-sqlite3-on-centos7/ for updating on CentOS 7 your SQLite version. Probably you have centos 7 x64 so you get in more troubles, because sqlite3 is not provided in x64. I have to say that I always have this kind of problems ^^, so actually it's not funny. After reading this: https://stackoverflow.com/questions/8328250/centos-64-bit-bad-elf-interpreter sudo yum install glibc.i686 Then you probably run into another problem: Multilib version problems found. This often means that the root.... yum install zlib-1.2.7-18.el7.x86_64 -> i686 and x86_64 have to be the same. Then you have to install zlib in the correct version: yum install zlib-1.2.7-18.el7.x86_64 sudo yum install glibc.i686 -> this will work now! After that you can check the version again and pray that it's working: sqlite3 --version Ouput: 3.27.1 2019-02-08 Information: What's happening now is that you run sqlite in 32-bit mode and not anymore 64-bit. But it shouldn't be a big deal (I hope so). Now we do the following: (Maybe your DB is in a different location) sqlite3 /var/lib/emby/data/library.db "update MediaItems set Images=null where Images like '%audiodb%'" Now we can run the fixing command from emby because of this bug: https://emby.media/community/index.php?/topic/69167-emby-server-4010-crashing-on-music-playback update MediaItems set Images=null where Images like '%audiodb%' Now I do also a Vacuum, Analyze, Reindex (I have read this should increase the performance) sqlite3 /var/lib/emby/data/library.db "VACUUM" sqlite3 /var/lib/emby/data/library.db "ANALYZE" sqlite3 /var/lib/emby/data/library.db "REINDEX" exit reboot This was it, now everything should be fine . My database size was 1,2 gb and now it's 500mb but it looks great and everything is still here. As last I made a testround and I was not able to create this exception again on my DB (just a short test), usually it didn't took long at my database and I recieved this exception. So I probably can confirm this! 1
Luke 42221 Posted July 18, 2019 Posted July 18, 2019 How to vacuum your Emby server database: https://emby.media/community/index.php?/topic/75510-42032-vacuum-database-config-switch/ Thanks.
