iBoss 31 Posted March 22, 2020 Author Posted March 22, 2020 Have you updated to emby server 4.4? Just now ... I'll try with the new update and let you know.
iBoss 31 Posted July 23, 2020 Author Posted July 23, 2020 @Luke@ebr On 3/22/2020 at 6:07 PM, ebr said: Right, so the issue with the wrong sub being selected does not exist in that case. The syncing is something with the delivery on the server during the transcode. Might need @@softworkz to look at that. As for the wrong one being selected - it appears the srt subs are being delivered to the app twice and that is what is messing up the indexing - but only if there is also an ssa sub to throw them off. Please is there any update on this issue
ebr 16337 Posted July 24, 2020 Posted July 24, 2020 17 hours ago, iBoss said: Please is there any update on this issue I believe the app issue for sub selection was dealt with...
iBoss 31 Posted July 24, 2020 Author Posted July 24, 2020 10 minutes ago, ebr said: I believe the app issue for sub selection was dealt with... ?! not only the selection, also it's out of sync Is this will be fixed soon? Please your support .... All my media totally are not watchable on Android TV
ebr 16337 Posted July 24, 2020 Posted July 24, 2020 18 hours ago, iBoss said: The syncing is something with the delivery on the server during the transcode. Might need @@softworkz to look at that. @softworkz
iBoss 31 Posted February 28, 2021 Author Posted February 28, 2021 @softworkz This issue from 2019 and still not fixed Please your support Thanks
ebr 16337 Posted February 28, 2021 Posted February 28, 2021 Can you please test your issue with the latest beta of the app and then lets look at it fresh if it still exists as many things have changed. Thanks.
iBoss 31 Posted July 16, 2021 Author Posted July 16, 2021 @ebr fixed and not fixed. If I play the movie from the beginning it will work ... if I make fast- forward (lets say 20 min), it will be not synced, if I just press rewind it will be synced do you need a log file? emby beta 2.0.31g Thanks
ebr 16337 Posted July 18, 2021 Posted July 18, 2021 Can you please try with this app and see if it has the same issue? 1
iBoss 31 Posted July 18, 2021 Author Posted July 18, 2021 @ebr Many thanks it works when this will be in a stable ver.?
Luke 42245 Posted July 19, 2021 Posted July 19, 2021 7 hours ago, iBoss said: @ebr Many thanks it works when this will be in a stable ver.? So you side loaded the standard Emby android app on your android tv device?
iBoss 31 Posted July 19, 2021 Author Posted July 19, 2021 (edited) 9 hours ago, Luke said: So you side loaded the standard Emby android app on your android tv device? what do you mean by Standard? Is this link for Android mobile emby or TV emby app?! https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 Edited July 19, 2021 by iBoss
rodainas 191 Posted July 19, 2021 Posted July 19, 2021 (edited) 8 minutes ago, iBoss said: what do you mean by Standard? Is this link for Android mobile emby or TV emby app?! https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 He is referring to mobile android app. Thats the android mobile app. Edited July 19, 2021 by rodainas
iBoss 31 Posted July 19, 2021 Author Posted July 19, 2021 27 minutes ago, rodainas said: He is referring to mobile android app. Thats the android mobile app. Ok so the mobile app is works when I installed it on android TV ... but emby for Android TV still has issue
rodainas 191 Posted July 19, 2021 Posted July 19, 2021 22 minutes ago, iBoss said: Ok so the mobile app is works when I installed it on android TV ... but emby for Android TV still has issue The emby android mobile app is various steps ahead of the androidtv app (compatibility with codecs, less bugs, features, improvements etc.), thats how I have always seen that. Someone from the team can give you a more precise answer than me here.
iBoss 31 Posted July 19, 2021 Author Posted July 19, 2021 1 hour ago, rodainas said: The emby android mobile app is various steps ahead of the androidtv app (compatibility with codecs, less bugs, features, improvements etc.), thats how I have always seen that. Someone from the team can give you a more precise answer than me here. So what is the point that @ebr gives me the link of emby mobile app to test it on Android TV?
rodainas 191 Posted July 19, 2021 Posted July 19, 2021 1 hour ago, iBoss said: So what is the point that @ebr gives me the link of emby mobile app to test it on Android TV? Well I suppose, to troubleshoot the problem easier.
Luke 42245 Posted July 21, 2021 Posted July 21, 2021 On 7/19/2021 at 12:11 PM, iBoss said: So what is the point that @ebr gives me the link of emby mobile app to test it on Android TV? It usually gets most updates to the video player a little earlier, so if the issue is resolved in that app, then it's a good sign that the fix will be coming to the android tv app as well. Thanks. 1
iBoss 31 Posted July 21, 2021 Author Posted July 21, 2021 2 minutes ago, Luke said: It usually gets most updates to the video player a little earlier, so if the issue is resolved in that app, then it's a good sign that the fix will be coming to the android tv app as well. Thanks. Great Thanks
iBoss 31 Posted July 30, 2022 Author Posted July 30, 2022 Hi @Luke I know this is a very old topic ... but it is a same issue in the past you are using mpv player on emby android mobile which is a fully support ASS file (that was a feature). and my issue in this topic is this ASS does not work in emby android TV version which don't have mpv player embedded inside it now unfortunately, you seems change the internal player for emby android mobile too; for from mpv to another one which does not support ASS. So, emby android mobile and emby android tv do not support ASS anymore .... please is there any plane to support it. ASS is a very important format for anime and it is really a big feature that emby can operate it. Now the only apps are fully support ASS is emby for iOS and macOS Thanks 1
ebr 16337 Posted July 30, 2022 Posted July 30, 2022 3 hours ago, iBoss said: So, emby android mobile and emby android tv do not support ASS anymore Hi. Yes they do. Can we please look at an example of your issue?
iBoss 31 Posted July 30, 2022 Author Posted July 30, 2022 (edited) 1 hour ago, ebr said: Hi. Yes they do. Can we please look at an example of your issue? I think you mean by yes it show the subtitle .. what I mean it is not fully support. The two attached screenshots give the difference between emby ios (perfect) and android 01: iOS and 02: Android please look at the top and bottom fonts. emby android use only its own one font for entire subtitle and ignore ass fonts. Edited July 30, 2022 by iBoss
Luke 42245 Posted July 31, 2022 Posted July 31, 2022 Hi, what version of the Android app do you have?
iBoss 31 Posted August 1, 2022 Author Posted August 1, 2022 10 hours ago, Luke said: Hi, what version of the Android app do you have? hi Luke emby android mobile 3.2.57
