KumarjitDey 103 Posted February 1, 2019 Posted February 1, 2019 Some theme musics are loud, for which I have to reduce the volume; and then again the media sound (that of movies/shows) are inaudible in that reduced volume, so I have to increase the volume again. So I wish there was a setting just for theme music in the settings beneath the "Enable Theme Music" option
Carlo 4561 Posted February 1, 2019 Posted February 1, 2019 It's the same issue as playing one movie that is soft then the next blasts you out of the chair! You could run each of your themed music files through a script or program to normalize the volume. You would only have to do it one time for each and then not worry about it again. Pain in the butt, but worth it long term.
