mnk 1 Posted February 1, 2019 Posted February 1, 2019 Hi, When i change a setting on the library setting menu, it is not saved. For example, if I check the "TheMovieDb" Box on the season metadata option, it is not saved.On my server, I can't see the library pictures ont the library Setting Menu.I got the version 4.0.1.0 of Emby.Thanks for your help.
Happy2Play 9806 Posted February 1, 2019 Posted February 1, 2019 What browser? But I have no issues in Chrome, Firefox, or Edge.
mnk 1 Posted February 1, 2019 Author Posted February 1, 2019 I tried on Chrome, firefox and Edge, I have the same behaviour.Do you think, I have to reinstall Emby ?I use it since 2016 and I don't know if the successsive updates/upgrades have created some errors on the application.My server is installed on CentOS Linux release 7.6.1810 (Core).
Luke 42217 Posted February 2, 2019 Posted February 2, 2019 Is this an existing library, or when setting up a new library?
mnk 1 Posted February 2, 2019 Author Posted February 2, 2019 I created an new library for the test today and it's ok.The problem only appears on my existing libraries. What is the best solution to resolve it ? Create new libraries or make a fresh install of emby ? Does it remove datas like viewing data ?
Theogeek 6 Posted February 2, 2019 Posted February 2, 2019 This is affecting me as well. Existing libraries don't keep changes to settings. Emby Server 4.0.1.0.
mnk 1 Posted February 4, 2019 Author Posted February 4, 2019 Hello,I think I found a solution.I renamed all my libraries and the settings are now saved. Library images have reappeared in the settings menu too. 1
Luke 42217 Posted February 4, 2019 Posted February 4, 2019 Did you upgrade from an earlier version of Emby?
mnk 1 Posted February 4, 2019 Author Posted February 4, 2019 Yes I upgraded from 4.0.0.2 and 3.5.2.0 before
Theogeek 6 Posted February 5, 2019 Posted February 5, 2019 Did you upgrade from an earlier version of Emby? Yes, I noticed this after upgrading to 4.0.1.0 from 4.0.0.1.
