PrincessClevage 175 Posted January 31, 2019 Posted January 31, 2019 Any ideas on how to troubleshoot remote not working? I was working on the back of my htpc and bumped something and since my remote won’t work. I can see on the ir receiver the signal light when I push a button on the remote and I have tried uninstalling the cec driver and the ehome receiver and also tried a different USB port for the ir receiver and uninstalled ET and reinstalled. A bit stuck...
Luke 42242 Posted February 1, 2019 Posted February 1, 2019 Is this still an issue? What kind of remote is it?
PrincessClevage 175 Posted February 1, 2019 Author Posted February 1, 2019 Yes I have come to the conclusion that my old wmc hp IR receiver may be at fault as I have tested it on another pc and it fails. My remote is the original Xbox large remote and I will source another Ir receiver today and test.
Luke 42242 Posted February 2, 2019 Posted February 2, 2019 Thanks for the info. In your case just FYI, the cec driver is not related. That's something that would only come into play if you wanted to use your TV remote control, and your TV remote supported hdmi-cec.
PrincessClevage 175 Posted February 3, 2019 Author Posted February 3, 2019 Thanks for the info. In your case just FYI, the cec driver is not related. That's something that would only come into play if you wanted to use your TV remote control, and your TV remote supported hdmi-cec.Thanks Luke, ended up being the IR receiver gave out, I ended up buying a second hand Microsoft Mce IR receiver and remote (which I find easier to map and use than harmony etc) and working well again.
