Luke 42272 Posted April 25, 2024 Posted April 25, 2024 2 hours ago, rbjtech said: Yep - it now appears the logs are not using the previously method.. Infact - it appears they are not formulating a decent error log at all for failed auth .. All they appear to be logging is via the UserManager - the IP info is now in a different http response message, unrelated to the failure .. oh dear. Luckily I use Scripter-X to send alerts via 'On Auth failure' so that continues to work just fine (I got a pushover alert with this test) but if you are using fail2ban or ipban at the server level (and not upstream on a reverse proxy) then this is now going to require some more work. 2024-04-25 16:51:53.652 Error DefaultAuthenticationProvider: Invalid username or password. No user named Baduser exists 2024-04-25 16:51:53.653 Info UserManager: Authentication request for Baduser has been denied. 2024-04-25 16:51:53.661 Debug Notifications: Sending notification: Failed Login Attempt from Baduser on <server> 2024-04-25 16:51:53.661 Error Server: Invalid username or password entered. 2024-04-25 16:51:53.661 Info Server: http/1.1 Response 403 to 1.2.3.4. Time: 10ms. POST http:/<server>/emby/Users/authenticatebyname?... 2024-04-25 16:51:53.716 Info HttpClient: POST https://api.pushover.net/1/messages.json @Luke- Hi - Any reason why the previous log entry for failed Auth was changed ? That's a mistake. It will be resolved in the next 4.8.X maintenance release. Thanks. 3
K22R8CT 25 Posted April 29, 2024 Posted April 29, 2024 Thanks. Will the fix use the same format as emby beta (below)? 2024-04-29 14:22:25.361 Warn Server: AUTH-ERROR: 10.0.1.4 - Invalid username or password entered.
Luke 42272 Posted April 29, 2024 Posted April 29, 2024 4 minutes ago, K22R8CT said: Thanks. Will the fix use the same format as emby beta (below)? 2024-04-29 14:22:25.361 Warn Server: AUTH-ERROR: 10.0.1.4 - Invalid username or password entered. Yes. 2
