SuperMinecraftKid 5 Posted January 31, 2019 Posted January 31, 2019 (edited) When I attempt to manually enter in the details of a show, auto-organize will pop up with "Error: null" as seen in this screenshot. http://prntscr.com/meka8o Here is an error report I found in the log. *** Error Report *** Version: 4.1.0.2 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd_{version}_amd64.txz -noautorunwebapp Operating system: Unix 11.2.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Jan 24 02:13:58 UTC 2019) Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.Exception: System.Exception: No provider metadata found for That Time I Got Reincarnated as a Slime season 1 episode 1 at Emby.AutoOrganize.Core.FileOrganizationService+<PerformOrganization>d__33.MoveNext () [0x000c9] in <e7a0af64fd2d485f98638cc551e975e2>:0 Source: Emby.AutoOrganize TargetSite: Void MoveNext() Do I need to enable more metadata dbs? As I said before, the show shows up when I manually enter in the details. http://prntscr.com/mekbnz Running emby 4.1.0.2 (didn't work on 4.0.1.0 either) on FreeNAS-11.2-RELEASE-U1 Any help would be appreciated! embylog.txt Edited January 31, 2019 by SuperMinecraftKid
Luke 42239 Posted January 31, 2019 Posted January 31, 2019 Hi there, please attach the complete emby server log. thanks.
SuperMinecraftKid 5 Posted January 31, 2019 Author Posted January 31, 2019 (edited) Hi Luke, the log has been attached Edited January 31, 2019 by SuperMinecraftKid
SuperMinecraftKid 5 Posted January 31, 2019 Author Posted January 31, 2019 Hi there, please attach the complete emby server log. thanks.
Luke 42239 Posted February 2, 2019 Posted February 2, 2019 HI there, can you please shutdown emby server, then delete the anime plugin .dll file from this folder: /var/db/emby-server/plugins Then start the server back up and see how it compares. thanks.
SuperMinecraftKid 5 Posted February 3, 2019 Author Posted February 3, 2019 HI there, can you please shutdown emby server, then delete the anime plugin .dll file from this folder: /var/db/emby-server/plugins Then start the server back up and see how it compares. thanks. That did the trick! Thanks!
