TiaanGR 2 Posted December 23, 2021 Posted December 23, 2021 Hi there All, Thanks for all the help and advice. I decided to build a PC with a Core I3 10th gen and with a 1030 just for some exstra transcoding capabilities. Sorry for onky replying now but been a bit busy lately. Kind Regards,
Happy2Play 9802 Posted December 23, 2021 Posted December 23, 2021 (edited) 6 minutes ago, TiaanGR said: Hi there All, Thanks for all the help and advice. I decided to build a PC with a Core I3 10th gen and with a 1030 just for some exstra transcoding capabilities. Sorry for onky replying now but been a bit busy lately. Kind Regards, But a 1030 will only have decoding capabilities not encoding. So the cpu will do more than the card. Check that model on the chart. Video Encode and Decode GPU Support Matrix [NEW] | NVIDIA Developer Edited December 23, 2021 by Happy2Play
TiaanGR 2 Posted December 23, 2021 Posted December 23, 2021 Hi there, Thanks. I am aware. The pc will only be used for emby it will be a server running Linux so i am not to stressed about the gpu.
Carlo 4561 Posted December 23, 2021 Posted December 23, 2021 (edited) But it's a 10th gen i3 so he will have UHD Graphics 630 built in. That's good for nearly half a dozen SDR hardware transcodes. It should also handle tone mapped 4K HDR quite well too. Nothing wrong with that choice at all. Did you buy a complete system? Have it up and running yet? Edited December 23, 2021 by cayars
TiaanGR 2 Posted December 24, 2021 Posted December 24, 2021 Hi, Yes, I am planning on doing the complete system, just busy saving up but had enough for that server but not for the pc
