blackcoffee 2 Posted January 29, 2019 Posted January 29, 2019 How to secure Emby using LetsEncrypt and Nginx Reverse Proxy by modifying Docker containers in Openmediavault. https://youtu.be/jYoDyoH2C0A
Brother_ 0 Posted December 18, 2020 Posted December 18, 2020 Hello. Is there a new guide for OMV5? It seems that tutorial was for OVM4 and is outdated.
Luke 42246 Posted December 18, 2020 Posted December 18, 2020 6 hours ago, Brother_ said: Hello. Is there a new guide for OMV5? It seems that tutorial was for OVM4 and is outdated. Hi, I'm not sure but they should be somewhat similar, right?
Brother_ 0 Posted December 18, 2020 Posted December 18, 2020 4 hours ago, Luke said: Hi, I'm not sure but they should be somewhat similar, right? Unfortunately not. I am a new user of Linux, and the video's instructions are for the last version of OMV (OMV4). The interface and layout have compactly changed since then. I'm sure it's possible to do all the same steps in the command line if you are an avid Linux user. However, I am not. Proper instructions would be appreciated for beginners like me.
MRobi 161 Posted December 20, 2020 Posted December 20, 2020 (edited) On 18/12/2020 at 14:37, Brother_ said: Unfortunately not. I am a new user of Linux, and the video's instructions are for the last version of OMV (OMV4). The interface and layout have compactly changed since then. I'm sure it's possible to do all the same steps in the command line if you are an avid Linux user. However, I am not. Proper instructions would be appreciated for beginners like me. From what I saw in the video, OMV supports docker. You could always use jc21's container for nginx reverse proxy manager which has a pretty simple to use GUI and tons of youtube guides on how to do it. This will make the nginx/let's encrypt side of things very simple and then you just need to follow the video for changing the emby settings. https://github.com/jc21/nginx-proxy-manager Edited December 20, 2020 by MRobi 1
