nobody01 89 Posted January 29, 2019 Posted January 29, 2019 Is there a way to set when I press LiveTV from Main screen to goto the Guide instead of Programmes?
Luke 42244 Posted January 29, 2019 Posted January 29, 2019 Hi there, have you explored your user home screen settings?
nobody01 89 Posted January 29, 2019 Author Posted January 29, 2019 Hi there, have you explored your user home screen settings? Slaps myself around the face! 2
nobody01 89 Posted January 29, 2019 Author Posted January 29, 2019 Scrap that, available on web but not on Android
samuelqwe 317 Posted January 30, 2019 Posted January 30, 2019 Scrap that, available on web but not on Android Mobile apps (Android or iOS) should reflect the same behaviour as on the web, unless you are referring to Android TV. In that case, there is no option for that at the moment.
ebr 16337 Posted January 30, 2019 Posted January 30, 2019 unless you are referring to Android TV. In that case, there is no option for that at the moment. That is not true. You absolutely can configure your default landing tab to any of the available ones in the Android TV app. Scroll to the right to the "Settings" tab in any library. 1
nobody01 89 Posted January 30, 2019 Author Posted January 30, 2019 That is not true. You absolutely can configure your default landing tab to any of the available ones in the Android TV app. Scroll to the right to the "Settings" tab in any library. I hunted for a while and couldn't find it. Will test again and feedback.
ebr 16337 Posted January 30, 2019 Posted January 30, 2019 I hunted for a while and couldn't find it. Will test again and feedback. You couldn't find the Settings tab? We hope to re-arrange how these are presented in the not too distant future to make that much easier.
nobody01 89 Posted January 30, 2019 Author Posted January 30, 2019 You couldn't find the Settings tab? We hope to re-arrange how these are presented in the not too distant future to make that much easier. Correct - I never knew there was a Settings along the top tab within LiveTV for both FireTV and AndroidTV you can't see this. When your in the Guide there is also a COG icon for settings so looked here naturally but didn't find the default. I have now found the Settings tab after looking for it properly and changed to Grid view as default. Would be good if there was a global Setting for this within the main page settings, similar to web view.
ebr 16337 Posted January 30, 2019 Posted January 30, 2019 I have now found the Settings tab after looking for it properly and changed to Grid view as default. Would be good if there was a global Setting for this within the main page settings, similar to web view. So you don't think that locating the setting right where it takes effect is an easier method? You'd rather have a monolithic dialog with all settings in it?
nobody01 89 Posted January 30, 2019 Author Posted January 30, 2019 So you don't think that locating the setting right where it takes effect is an easier method? You'd rather have a monolithic dialog with all settings in it? Just an easier method would make sense. Even like Settings > Libraries > *list all libraries > Library Setting
ebr 16337 Posted January 30, 2019 Posted January 30, 2019 Settings > Libraries > *list all libraries > Library Setting What we have now is actually one step less and, in my mind, increases the value by creating proper context for it: Library->Settings->Library Setting So, you are in a library and wish to change how it appears - you go to the settings right in that library and make the change. Instead of leaving the library you are in to find the global settings page and then search that page for the library you were just in to find the setting you wish to change. That's what we were going for here anyway...
samuelqwe 317 Posted January 30, 2019 Posted January 30, 2019 That is not true. You absolutely can configure your default landing tab to any of the available ones in the Android TV app. Scroll to the right to the "Settings" tab in any library. Ah, thanks for clearing that up!
Carlo 4561 Posted February 5, 2019 Posted February 5, 2019 NO, keep it how it is in Android TV. Keep local settings in the section they apply to. Other Global settings in the main app setting section. That makes it much clearer how they apply (it's scope) as well as keep the amount of settings much smaller in those local settings. You can get right to the settings that apply in those sections.
