ken-ji 0 Posted January 29, 2019 Posted January 29, 2019 Just noticed this in 4.0.1.0 docker container while trying to watch something in Hi10p with subtitles frame= 1659 fps= 16 q=-0.0 size=N/A time=00:03:18.24 bitrate=N/A speed=1.92x frame= 1664 fps= 16 q=-0.0 size=N/A time=00:03:18.31 bitrate=N/A speed=1.91x frame= 1671 fps= 16 q=-0.0 size=N/A time=00:03:18.81 bitrate=N/A speed= 1.9x So I shutdown the container, started a new container with the last stable version 3.5.3.0: frame= 1596 fps= 80 q=23.0 size=N/A time=00:01:06.85 bitrate=N/A speed=3.37x [segment @ 0x7c4740] Opening '/transcoding/transcoding-temp/7bfe456162a15e3463f845961edcc264.m3u8.tmp' for writing [segment @ 0x7c4740] Opening '/transcoding/transcoding-temp/7bfe456162a15e3463f845961edcc26422.ts' for writing frame= 1645 fps= 81 q=23.0 size=N/A time=00:01:08.90 bitrate=N/A speed=3.38x [segment @ 0x7c4740] Opening '/transcoding/transcoding-temp/7bfe456162a15e3463f845961edcc264.m3u8.tmp' for writing [segment @ 0x7c4740] Opening '/transcoding/transcoding-temp/7bfe456162a15e3463f845961edcc26423.ts' for writing frame= 1691 fps= 81 q=23.0 size=N/A time=00:01:10.95 bitrate=N/A speed= 3.4x Why is there such a great disparity in performance? files I could play without issue in the previous stable no longer play without stalling... For quick reference, I'm running on a Pentium G4620 with /dev/dri mapped into the docker ffmpeg-transcode-3.5.3.0.txt ffmpeg-transcode-4.0.1.0.txt
Luke 42246 Posted January 29, 2019 Posted January 29, 2019 Strange, seems like the only difference is the chosen vaapi device. Can you play from the beginning on 4.0 and provide a log? Just to rule that out. Can you also attach the hardware detect log. Thanks.
ken-ji 0 Posted January 29, 2019 Author Posted January 29, 2019 Here it is. hardware_detection-63684393706.txt ffmpeg-transcode-4.0.1.0.txt
Luke 42246 Posted February 1, 2019 Posted February 1, 2019 What Emby app are you playing from? The other difference is the technique being used to burn in the subtitles.
ken-ji 0 Posted February 1, 2019 Author Posted February 1, 2019 (edited) The initial log snippets are using the Roku client The full log, was using the browser client as i generated the logs remotely. Edited February 1, 2019 by ken-ji
Luke 42246 Posted February 2, 2019 Posted February 2, 2019 In server transcoding settings did you turn off on the fly subtitle extraction?
ken-ji 0 Posted February 2, 2019 Author Posted February 2, 2019 When its turned on, no burned in subtitles show up... The specific File I'm trying has embedded ASS subtitles
Luke 42246 Posted February 2, 2019 Posted February 2, 2019 Ok so in your case you will need to keep that unchecked. When it is checked, we don't burn them in and instead extract them as text and render them directly in the video player. However, if you're not seeing subtitles, that means the extraction is too slow in your environment which means you need to disable it. If you also turn off the subtitles prior to playback, how does that perform?
ken-ji 0 Posted February 2, 2019 Author Posted February 2, 2019 Its actually very fast when subtitles are turned off... about the same speed as in 3.5.3 Maybe there's some issue with ffmpeg rendering the subtitles?
Luke 42246 Posted February 3, 2019 Posted February 3, 2019 I don't think there's an issue, it's just that burning in subtitles is a very expensive process. It brings quite a bit of additional overhead. If you would consider using external text subtitles instead this problem then goes away because the subtitles can be delivered to the video player separately.
ken-ji 0 Posted February 3, 2019 Author Posted February 3, 2019 My point is that in 3.5.3 I could transcode with subtitles burned in running at 90fps while in 4.0 it goes below 30fps. It's like in 3.5.3 there's next to no overhead with subtitles burned in. But there's a huge perf drop in 4.0
Luke 42246 Posted February 3, 2019 Posted February 3, 2019 The problem is the gpu transcoding failed in 3.5 and then we automatically switched to CPU transcoding in order to allow the video to play. You can see this in your 3.5 log: [Parsed_subtitles_2 @ 0x23826c0] Shaper: FriBidi 1.0.4 (SIMPLE) [Parsed_subtitles_2 @ 0x23826c0] Loading font file '/config/fonts/DroidSansFallback.ttf' [Parsed_subtitles_2 @ 0x23826c0] Using font provider fontconfig Impossible to convert between the formats supported by the filter 'Parsed_hwupload_1' and the filter 'auto_scaler_1' Error reinitializing filters! Failed to inject frame into filter network: Function not implemented Error while processing the decoded data for stream #0:1 [aac @ 0x7d8600] Qavg: 28048.062 [aac @ 0x7d8600] 2 frames left in the queue on closing Conversion failed! So now in 4.0 we have corrected these problems so that the GPU can be used, however in your case, at least for this one example, you are actually better off with CPU.
ken-ji 0 Posted February 4, 2019 Author Posted February 4, 2019 What I don't get is why the CPU encoding is very fast in 3.5.3 when turning off HW acceleration in 4.0 is very slow. I'll look into making sure I've accounted for all the variables and differences (and looking for other test files)
Luke 42246 Posted February 4, 2019 Posted February 4, 2019 CPU should be the same in both releases, but if you can provide log examples for comparison then i can provide some explanation. In post #1 you already have a CPU log of 3.5.3, so if you could provide one from 4.0+ under identical conditions that would be great, thanks.
ken-ji 0 Posted February 11, 2019 Author Posted February 11, 2019 Right so just to be sure everything is as identical as I can make it, I made two new containers, one for 3.5.3 and one for 4.0.1 I grabbed the transcode logs for both of them supposedly using HW acceleration VAAPI. I also turned off the subtitles in the same file for 4.0.1 so that I could also compare the raw transcode speeds agains 3.5.3 (as it seems to be just a tad faster than 3.5.3 with subtitles) ffmpeg-transcode-emby353.txt ffmpeg-transcode-emby4.txt ffmpeg-transcode-emby4-nosubs.txt
Luke 42246 Posted February 11, 2019 Posted February 11, 2019 I already explained this to you. 3.5 is not actually using vaapi even though you have it turned on. It is trying to use vaapi, then failing and automatically switching to CPU. That makes this comparison apples to oranges. The only comparison you could make would be to disable hardware acceleration on both.
ken-ji 0 Posted February 12, 2019 Author Posted February 12, 2019 So I disabled acceleration for both. and the results are almost the same with each other which should be expected, except for the fact 3.5.3 w/o hw acceleration is a lot slower than the one with hw acceleration turned on but failed and continued to use CPU according to you. ffmpeg-transcode-emby353.txt ffmpeg-transcode-emby4.txt
softworkz 5133 Posted February 15, 2019 Posted February 15, 2019 I already explained this to you. 3.5 is not actually using vaapi even though you have it turned on. It is trying to use vaapi, then failing and automatically switching to CPU. That makes this comparison apples to oranges. The only comparison you could make would be to disable hardware acceleration on both. So I disabled acceleration for both. and the results are almost the same with each other which should be expected, except for the fact 3.5.3 w/o hw acceleration is a lot slower than the one with hw acceleration turned on but failed and continued to use CPU according to you. I'm afraid I'm not sure what you're asking about? Your latest logs are both without hwa (CPU only) and both with subtitle burn-in. The transcoding speeds are almost identical, just as @@Luke had said.
Luke 42246 Posted February 15, 2019 Posted February 15, 2019 He believes the CPU only transcoding is faster in 3.5.
softworkz 5133 Posted February 15, 2019 Posted February 15, 2019 from his latest logs: Log from 3.5: frame=34094 fps= 49 q=-1.0 Lsize=N/A time=00:23:42.01 bitrate=N/A speed=2.06x Log from 4.0 frame=14065 fps= 52 q=28.0 size=N/A time=00:09:47.30 bitrate=N/A speed=2.16x
ken-ji 0 Posted February 15, 2019 Author Posted February 15, 2019 Yes, @@Luke states the original log for 3.5.3 with HWA turned on didn't use HWA due to some incompatibility during the transcode. But I didn't get the same performance when I turned off HWA.
