psykix 97 Posted January 29, 2019 Posted January 29, 2019 (edited) Couple of questions. Is HDR colour space mapping supported for 4k HDR movies on non-HDR devices? Also, can someone recommend the cheapest low profile, single slot (needs to go in a HP Microserver) GPU which supports hardware acceleration for H265? Does such a card even exist? Would a P400 work for hardware acceleration with Emby? Edited January 29, 2019 by psykix
Coxeroni 27 Posted January 29, 2019 Posted January 29, 2019 Is HDR colour space mapping supported for 4k HDR movies on non-HDR devices? Nope.
psykix 97 Posted January 29, 2019 Author Posted January 29, 2019 Nope. Ok, is it in the pipeline then?
Coxeroni 27 Posted January 29, 2019 Posted January 29, 2019 As I understood it is highly anticipiated by the users but technically far from being easy to implement, so no one knows how long it will take and if it can be successfully implemented at all.
RanmaCanada 501 Posted January 29, 2019 Posted January 29, 2019 (edited) https://acqugroup.en.taiwantrade.com/product/m4-p107mdp-1620300.html# https://www.gearbest.com/graphics-video-cards/pp_1261865.html?utm_campaign=8001312&utm_source=cj&utm_medium=affiliate&from=affiliate_cj&cjevent=51245f6a23d611e980c800970a240614 Or a Quadro P1000, though it's still limited to 2 threads unless you use the hacks. It's cheaper to replace your server. Edited January 29, 2019 by RanmaCanada 1
Luke 42216 Posted January 29, 2019 Posted January 29, 2019 Hdr tone mapping is planned for the future. Thanks. 1
