alekslyse 0 Posted January 29, 2019 Posted January 29, 2019 I'm trying Emby for the first time from another known brand, and this far the experience has been good. Seems to load faster etc. And this could have been a topic many times before, but is it possible to change the color of the buttons, mainly the green color of play, status etc. I do not think the color is great in the newest design, at least the gradient of the green (personal opinion), and since its many personal opinions I would like to be able to change the color, is that possible?
Luke 42243 Posted January 29, 2019 Posted January 29, 2019 Hi, not for the buttons specifically, but have you tried the different theme options in the app?
alekslyse 0 Posted January 29, 2019 Author Posted January 29, 2019 Hi, not for the buttons specifically, but have you tried the different theme options in the app? Yeah - tried the themes. Only change I would like to see at least is to use the same green color as in the web app. The green used in the app I dont think fit in, and the green used in the web UI is much more modern, but that is of course my personal opinion.
ebr 16336 Posted January 29, 2019 Posted January 29, 2019 Yeah - tried the themes. Only change I would like to see at least is to use the same green color as in the web app. The green used in the app I dont think fit in, and the green used in the web UI is much more modern, but that is of course my personal opinion. Hi. We are using the same color, it is just toned down a bit because of the fact that most TV displays are quite bright. In our tests, using the exact same brightness of color was quite obnoxious on a TV .
Punch 19 Posted January 30, 2019 Posted January 30, 2019 What about a transparency option to adjust the theme colors and / or a transparent theme all together? Just an idea of course, we love customization : )
TylerV76 84 Posted January 30, 2019 Posted January 30, 2019 Or blue. Would love to swap the green for blue. Sent from my iPhone using Tapatalk
HairyBizRat 21 Posted December 8, 2024 Posted December 8, 2024 Any update on this? I to would like to change the green buttons on apps to another colour. from what I understand the CSS changes are for web browsers only. And themes changes in apps are just backgrounds as buttons are still green.
ebr 16336 Posted December 8, 2024 Posted December 8, 2024 58 minutes ago, HairyBizRat said: And themes changes in apps are just backgrounds as buttons are still green Hi. In the Android TV app, you have a choice of either a "neutral" color or the theme color for button highlights. This is in the display settings in the app.
