Kodi_Newcomer 27 Posted January 29, 2019 Posted January 29, 2019 Hello com, hello Team Emby, I have an Feature request. Because i have some problems with my setting for now. When kodi starts Emby Addon try'ed directly to Connect to the Emby server, but the Server is not there because He is wake uped through kodi. So he need normaly 15 seconds to wake up and ready to use. So but Emby Addon will Connect direct after kodi start. IT gives an error and i think Something a timeout, because i have time wait now many secconds bevor i can play a file from the server, and emby bring's the Message Welcome. So my Feature request maybe there is a way for a Connection delay setting after kodi start ? So i can set IT to 15 Seconds for example and then after this time Emby Addon try'ed the First Time to Connect to the Server. Greets, Newcomer
Solution Angelblue05 4132 Posted January 30, 2019 Solution Posted January 30, 2019 (edited) Already in place Wiki settings: https://github.com/MediaBrowser/plugin.video.emby/wiki/Settings#advanced Check the about Emby for Kodi in the wiki too. In the add-on settings > advanced. Edited January 30, 2019 by Angelblue05
Kodi_Newcomer 27 Posted January 30, 2019 Author Posted January 30, 2019 Yes sorry, this was my bad. I've probably looked over it 50 times and somehow just not seen or registered. That's been the case for a long time. Then I will test it. Thank you I must have tomatoes on my eyes. 1
