Galvaneal 1 Posted January 28, 2019 Posted January 28, 2019 Hello I have updated my NAS tot the 1817+ and since then the emby library scan will not complete. I have no extra plugins, only the ones that come with membership Here is PDF of my log file. I hope you can help me Regards Galvaneal EmbyLog.pdf
Luke 42241 Posted January 28, 2019 Posted January 28, 2019 Hi there, we're looking into this, thanks.
Galvaneal 1 Posted January 28, 2019 Author Posted January 28, 2019 Hi there, we're looking into this, thanks. thanks for picking this up so quick!
Luke 42241 Posted February 1, 2019 Posted February 1, 2019 Hi there, it's resolved for the next release, thanks.
solabc16 379 Posted February 1, 2019 Posted February 1, 2019 Hello @@Luke The other directory we should be making sure we ignore is... @eaDir ...we'd dealt with this previously, but if #recycle is causing a problem again, it'd be worth double checking this as well. Best - James
Galvaneal 1 Posted February 4, 2019 Author Posted February 4, 2019 Hi there, it's resolved for the next release, thanks. Hi Luke, thanks for this! Can you share when the next release is scheduled? And what was the issue?
Luke 42241 Posted February 4, 2019 Posted February 4, 2019 We'll be getting a release out very soon that includes the fix. It was performing certain operations repeatedly. Thanks.
Galvaneal 1 Posted February 21, 2019 Author Posted February 21, 2019 We'll be getting a release out very soon that includes the fix. It was performing certain operations repeatedly. Thanks. Hi Luke I have downloaded the latest patch but the problem remains. If i only make movie & tv-series library it works (as it did before) but as soon as i add my own personal photo's and family video's it gets stuck at 87% Here is another log attached. Do you have any suggestions what it could be? emby-log.pdf
solabc16 379 Posted February 21, 2019 Posted February 21, 2019 Hello @@Galvaneal There doesn't appear to be anything interesting going on in that log, probably because it's the log that rolled over at 00:00. Can you attach the previous log, that will likely have more information about the scan in it. Best - James
Galvaneal 1 Posted February 21, 2019 Author Posted February 21, 2019 Hello @@Galvaneal There doesn't appear to be anything interesting going on in that log, probably because it's the log that rolled over at 00:00. Can you attach the previous log, that will likely have more information about the scan in it. Best - James Hi James I hope this works emby-log v2.pdf
solabc16 379 Posted February 21, 2019 Posted February 21, 2019 Hello @@Galvaneal This log contains today's output as well, have a look for a log containing information from the 20th. emby-log.pdf 2019-02-21 00:00:00.104 2019-02-21 12:46:43.493 emby-log v2.pdf 2019-02-21 12:58:58.389 2019-02-21 13:00:04.943 Best - James
