xccxxx 11 Posted January 28, 2019 Posted January 28, 2019 (edited) Using addon version 4.01 and server version 4.0.10 im finding that seeking backwards on Kodi no longer works properly on a lot of my content - it often just freeze and get completely stuck (Although sometimes it will work as normal so its not every time). Not sure if its something with the new server version, or the new addon version, as I updated both at the same time. Just wondering if there is a fix for this - would reverting to an earlier add on version solve the issue, or is it something that is to do with the new server version? Edited January 28, 2019 by xccxxx
Angelblue05 4132 Posted January 28, 2019 Posted January 28, 2019 Depends on how you playback. Please provide your Kodi log capturing the issue. Thank you.
