Luke 42246 Posted January 28, 2019 Posted January 28, 2019 Hi there, can you please attach a server log? What happens when you try to scan the library? Thanks.
Akilian 5 Posted January 30, 2019 Author Posted January 30, 2019 Nothing. On the dashboard notifications it says scan failed. Could not find a part of the path '/var/lib/emby-server/root/default/Ellie's Movies'.at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound)at System.IO.Enumeration.FileSystemEnumerator`1..ctor(String directory, EnumerationOptions options)at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options)at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options)at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options)at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive)at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path)at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, IServerApplicationHost appHost, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts)at MediaBrowser.Controller.Entities.CollectionFolder.CreateResolveArgs(IDirectoryService directoryService, Boolean setPhysicalLocations)at MediaBrowser.Controller.Entities.CollectionFolder.RequiresRefresh()at MediaBrowser.Providers.Manager.MetadataService`2.RefreshMetadata(BaseItem item, MetadataRefreshOptions refreshOptions, CancellationToken cancellationToken)at MediaBrowser.Controller.Entities.BaseItem.RefreshMetadata(MetadataRefreshOptions options, CancellationToken cancellationToken)at Emby.Server.Implementations.Library.LibraryManager.ValidateTopLibraryFolders(CancellationToken cancellationToken)at Emby.Server.Implementations.Library.LibraryManager.PerformLibraryValidation(IProgress`1 progress, CancellationToken cancellationToken)at Emby.Server.Implementations.Library.LibraryManager.ValidateMediaLibraryInternal(IProgress`1 progress, CancellationToken cancellationToken)at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options)
Luke 42246 Posted January 30, 2019 Posted January 30, 2019 Can you please attach the complete emby server log? thanks !
Solemn 0 Posted January 30, 2019 Posted January 30, 2019 Hi, starting with emby couple of days ago, had the same error. Tried to solve it with an update from 3.0.6 to 4.0.1 without success. After enabling debug logging I came across a similar error message saying Could not find a part of the path '/var/lib/emby-server/root/default/...' First guess was there were some erranous links in accessing the directories under /var and just tried to work around with a symlink "ln -s /var/lib/emby /var/lib/emby-server". What should I say, seems like it had the expected effect, library scan works. Cheers, Solemn
Akilian 5 Posted January 31, 2019 Author Posted January 31, 2019 Hi, starting with emby couple of days ago, had the same error. Tried to solve it with an update from 3.0.6 to 4.0.1 without success. After enabling debug logging I came across a similar error message saying Could not find a part of the path '/var/lib/emby-server/root/default/...' First guess was there were some erranous links in accessing the directories under /var and just tried to work around with a symlink "ln -s /var/lib/emby /var/lib/emby-server". What should I say, seems like it had the expected effect, library scan works. Cheers, Solemn Yes, I went back to version 3. I'll try the symlink. Thanks.
Solemn 0 Posted January 31, 2019 Posted January 31, 2019 (edited) I'm still on v4, the fix is quick and dirty but apparently works on both releases. As this seems to to be coded somewhere in the source, is there a bug tracker or similar to file that? Edited January 31, 2019 by Solemn
Luke 42246 Posted January 31, 2019 Posted January 31, 2019 Please attach the emby server log, thanks.
Solemn 0 Posted February 1, 2019 Posted February 1, 2019 See attached log. embyserver-63684475895.txt
Solemn 0 Posted February 4, 2019 Posted February 4, 2019 I did, but the log was from before... I then created a symlink lrwxrwxrwx 1 root root 4 Jan 30 20:15 emby-server -> emby Now it does scan library.
