AmericanMike 18 Posted January 28, 2019 Posted January 28, 2019 (edited) When I was using NextPVR to stream my LiveTV through Emby, I was able to see the status of each tuner through NextPVR's "Show Status" option. Can I do something similar with Emby now I am not using NextPVR but am using my Hauppauge tuners natively? I have installed one 2255 and one 2250 giving me 4 tuners to use, however I don't think Emby is using all four as I get some recodings dropping out before the end or in some cases just an error when trying to watch a live channel. If no utility exists I will try to create the error and post some logs hoping someone can show me how to look at that. Thanks..... Edited January 28, 2019 by AmericanMike
PenkethBoy 2068 Posted January 28, 2019 Posted January 28, 2019 Not in Emby But the WinTv app gives you a status via settings>devices - which will give an indication if WinTv thinks a tuner is in use
