manf0001 4 Posted January 27, 2019 Posted January 27, 2019 Hello, I'm Running Emby Server 4.0.1.0 on CentOS 7.5 I've noticed that in my music collection it's not using or saving the folder or logo artwork into the Respected Group folder. So my Library Folder Structure is /Music/Group/Album I have the cover.jpg in each Album folder and that works fine. But in the Group folder I have folder.jpg or logo.png and emby doesn't reconize them. Via emby I went to edit images for the group and put the uploaded the desired image and it applies, but it doesn't save the file to the Library Group's folder. I know this because I have removed the folder.jpg from the folder and tried adding it in. It saves the picture but again not in the library. I found that it is saving them at /var/lib/emby-server/metadata/artists I also do have the option Save Artwork into Media folders enabled for the Music Library. But I would think that it shouldn't matter if I already have a folder pic in said folder. TIA
Luke 42246 Posted January 28, 2019 Posted January 28, 2019 Hi, metadata for music artists does not get saved in media folders because they are tagged items and not associated to folders. It is possible for the future though. Thanks.
manf0001 4 Posted January 30, 2019 Author Posted January 30, 2019 Ok so adding artwork via the Edit images is metadata, but why isn't it picking up the photo if I place it in the actual Artist Folder? According to the Wiki of the naming conventions for Music (https://github.com/MediaBrowser/Wiki/wiki/Music-naming) Images are supported in both artist and album folders. So if I have the following layout should this not work? \Music \Artist Name folder.jpg \Album Name cover.jpg 1- Song.mp3 2- Song.mp3 For me emby picks up the cover.jpg file fine under the albums, but it doesn't recognize the folder.jpg.
Luke 42246 Posted January 30, 2019 Posted January 30, 2019 Because at this time we do not correlate artists with folders, it comes from the embedded information within the audio file. It is difficult to determine if a folder is actually an artist folder. It's possible to look at this in the future though.
