vzane 2 Posted January 27, 2019 Posted January 27, 2019 Hi, I am a long time user of Emby for WMC. Currently running latest server beta (4.1.0.3) and latest WMC plugin beta (3.0.317). This combination has been working for at least one week but today I had the surprise of discovering that none of my 3 HTPC's are able to launch Emby in WMC anymore. I restarted the server and the HTPCs, made sure I am running the latest builds, but no luck. Basically Emby gets stuck at the splash screen (the one with the "flying dots"), and loops through those dots ad infinitum. Emby Theater and the Roku client both work fine. It seems to me that maybe the server received some update which made it incompatible with the WMC client. I am attaching the log from one of the HTPCs. Any ideas? Thanks in advance! MBClassic-26120195c296bfbe972446a92ce01b611823818.log
Solution Luke 42237 Posted January 27, 2019 Solution Posted January 27, 2019 It's due to an issue in the beta server, thanks. 1
vzane 2 Posted January 27, 2019 Author Posted January 27, 2019 Ok, thanks for confirming. I suppose this is planned to be fixed in the next release? Thanks again...
Luke 42237 Posted January 27, 2019 Posted January 27, 2019 Yes it will. Please use the testing area of the community for beta related feedback. Thanks.
Peter Nent 71 Posted January 27, 2019 Posted January 27, 2019 Same problem here.... After I reinstalled MCE version on my WMC system, I could log-in after entering the password. Auto-save of password set, but not working: everytime I start EMby via WMC/MCE, it askes password again, although I have set to auto-save the password....oeps....annoying.... Awaiting bugfix and support you very much ! Grtz, Peter
Luke 42237 Posted January 27, 2019 Posted January 27, 2019 Thank you for being a part of the testing team.
vzane 2 Posted January 31, 2019 Author Posted January 31, 2019 Happy to report that this problem is now fixed with server build 4.1.0.4. Thank you so much for the quick fix!
