cembry 1 Posted February 1, 2019 Author Posted February 1, 2019 Ok, for those of you willing to try the beta server, 4.1.0.4 has a possible fix. Thanks. I just installed beta server, 4.1.0.5. Stellans name can be searched, his page is displayed... Seems that the problem is solved. Thank you!
Luke 42217 Posted February 2, 2019 Posted February 2, 2019 Interesting, thanks for the info ! @@KarolKo, how about you?
KarolKo 0 Posted February 2, 2019 Posted February 2, 2019 (edited) Interesting, thanks for the info ! @@KarolKo, how about you? Hi @@Luke, I am waiting for the freebsd release to become available. Edited February 2, 2019 by KarolKo
KarolKo 0 Posted February 4, 2019 Posted February 4, 2019 I have seen there is already 4.1.0.6 but again no freebsd pkg. What happened?
Luke 42217 Posted February 5, 2019 Posted February 5, 2019 Sometimes the freebsd updates will take a little longer. We thank you for your patience. 1
KarolKo 0 Posted February 10, 2019 Posted February 10, 2019 Right, so I updated all dependencies to the latest version, installed 4.1.0.8 and I am still getting the same issue - as far I can tell. Instead of iconv I see libiconv installed though. Basically as soon as I open the browser and go to the Dashboard that includes "Latest movies", it crashes. I tried to also change the systems regional settings (on my PC I am browsing from), to US. But that did not make a difference either. Log-1.txt Log-2.txt Log-3.txt Log-4.txt Log-5.txt Log-6.txt
Luke 42217 Posted February 10, 2019 Posted February 10, 2019 Is there a newer mono runtime available?
Thomas64 40 Posted February 10, 2019 Posted February 10, 2019 (edited) Folks - Just wanted to add that this is happening to me when trying to scroll through Music via Chrome - running a completely new install of 4.0.1.0 on a new install of Windows Pro 1809 as well. I was going to hold off a bit longer on upgrading, but Schedules Direct has interestingly started to drop a lot of data out of the channel lineup (my subscription does not expire until July, I believe). So yesterday, I dusted off a spare laptop and fired everything up to kick the tires.. I just discovered this issue today when trying to listen to music and found this post. Attached is the server log from the last crash. It stops loading thumbnails of Albums half way through the second page and crashes. Didn't think to note which exact one appears to be the last to load.. I'd try now, but the new install is recording something for a few hours. (I'll do it later and update, if it helps.) Just wanted to pass the info along, since this happens on a completely fresh install of everything (with a sample range of media I copied to an external drive). I may flip a coin on installing the latest Beta, since this is a testing install anyway.. Thanks, Thomas Edited March 8, 2019 by Thomas64
Thomas64 40 Posted February 10, 2019 Posted February 10, 2019 (edited) Maybe this helps as well.. Thomas Edited March 8, 2019 by Thomas64
Luke 42217 Posted February 10, 2019 Posted February 10, 2019 We'll be getting a new stable out in the next day or so that has the fixes from the beta channel. Thanks.
KarolKo 0 Posted February 11, 2019 Posted February 11, 2019 I am afraid, mono was not amongst the upgraded packages. libidn2, gnutls, libva and webp.
KarolKo 0 Posted February 11, 2019 Posted February 11, 2019 It seems that the problem is related to the library item added via samba.
Luke 42217 Posted February 11, 2019 Posted February 11, 2019 It seems that the problem is related to the library item added via samba. What you could try instead of adding the smb path to Emby, is mount the smb in your operating system as a local share. Then add the local path to Emby.
manatails 2 Posted February 12, 2019 Posted February 12, 2019 I am experiencing a similar issue here, Emby crashes when one of the casts has diacritics in their name. Happening only after updating to 4.0 from 3.5.
Luke 42217 Posted February 12, 2019 Posted February 12, 2019 @@manatails, we're releasing Emby Server 4.0.2 today. Please try that. Thanks.
KarolKo 0 Posted February 13, 2019 Posted February 13, 2019 (edited) Hi @@Luke, so I can confirm, that mounting the samba share seems to have solved the issue for me. So far not a single crash. THANK YOU! Edited February 14, 2019 by KarolKo
Thomas64 40 Posted February 15, 2019 Posted February 15, 2019 Folks - Just an update... I upgraded to 4.0.2.0 - still crashing in the same spot when scrolling though Music Albums. Turned Debug Logging on, tried again. Turns out - Emby was choking on a corrupted file in one of the Artist Folders. Couldn't do anything with Windows to get rid of the file (everything errored out). Didn't want to install any 3rd party apps.. Ended up running CHKDSK - and there were actually 3 corrupted files/links related to the same Artist folder, which CHKDSK got rid of. There must have been some bad sectors or such on the external disk when I copied stuff off the machine running 3.5.3. All good now! Current error score: Emby V4 = 0 Me = 2 LOL Thanks, Thomas 1
Luke 42217 Posted February 22, 2019 Posted February 22, 2019 @@KarolKo so you can't get the /media folder added to the library? is that correct? The error you posted is related to the realtime monitor, which is different. Thanks.
