cembry 1 Posted January 26, 2019 Posted January 26, 2019 I am running EmbyServer on Windows 10 flawlessly till the update to v4. Since the update to v4 the EmbyServer,exe crashes just when browsing. Embytray.exe is running, Embyserver.exe is missing. I have to kill embytray.exe and start embyserver.exe again. My workaround is starting embyserver as service and keep it always up with the AlwaysUp application. I dont have to restart the server manually but the issue is still there. I find out that the crash happens everytime the db works with the actor "Stellan Skarsgård" - no matter if I want to search him, click on his page in the library or load movie detail with his name in it. I dont know any other db records leading to crash yet. I think it could be related to specials characters (i.e. å character in this name)... Is there a way to correct this issue? Thanks a lot!
Happy2Play 9806 Posted January 26, 2019 Posted January 26, 2019 I wonder why this only affects some users? @@Luke Could this be a regional language bug? As I don't see this issue on my Windows 10 v4.
cembry 1 Posted January 27, 2019 Author Posted January 27, 2019 If the problem is not Stellans name then it should be just coincidence and there is some other error related to his record. My windows language is set to czech so there could be a lot of strange characters to foreigners but the å is not used in czech ;-)
purger500 13 Posted January 27, 2019 Posted January 27, 2019 (edited) There is definitely problem with scandinavian names. Every movie and every show with this names crashes server (server hangs and must be terminated and started again - restart does not work). This problem is not introduced with v4,x, it exist for a long time. My workaround is that I delete scandinavian actors from shows and movies and lock actors fields in that shows/movies. My default input language in windows is croatian. My OS is windows 7 pro 64bit. Edited January 27, 2019 by purger500
purger500 13 Posted January 27, 2019 Posted January 27, 2019 I have just tested what happens when I search for Stellan Skarsgård... It happens that my server freezes as I expected. My server log is attached. This is very annoying. embyserver.txt
purger500 13 Posted January 27, 2019 Posted January 27, 2019 UPDATE: I have tried to change default input language to english, but that didn't help.
Luke 42217 Posted January 27, 2019 Posted January 27, 2019 That is still the big question, why this is happening to some users but not all. I am looking into it. Thanks.
Luke 42217 Posted January 27, 2019 Posted January 27, 2019 I have just tested what happens when I search for Stellan Skarsgård... It happens that my server freezes as I expected. My server log is attached. This is very annoying. Since you're using the coverart plugin, can you try removing that, then restarting the server, and see if it makes a difference?
purger500 13 Posted January 27, 2019 Posted January 27, 2019 I have just tried that but it didn't help.
cembry 1 Posted January 27, 2019 Author Posted January 27, 2019 The plugins I use are following: MovieDb (1.0.6.0) OMDb (1.0.3.0) Playback reporting (1.2.6.0) Reports (1.0.25.0) Backup & Restore (1.3.4.0) Statistics (2.0.8.0) The TVDB (1.0.1.0) I am not sure if any of this plugins could cause troubles, I hope it does not...
purger500 13 Posted January 28, 2019 Posted January 28, 2019 It seems that it was a windows 7 thing. I installed windows 10 and there is no mentioned problem anymore.
cembry 1 Posted January 28, 2019 Author Posted January 28, 2019 As I wrote at the start of this thread - I am running EmbyServer at Windows 10 (x64)... and the issue is there :-(
purger500 13 Posted January 28, 2019 Posted January 28, 2019 Oh sorry, I overlooked that information.
KarolKo 0 Posted January 28, 2019 Posted January 28, 2019 (edited) I am running Emby 4.0.1.0 on FreeNAS and my server is also crashing when I try to browse my Library, via web or via Android app. Can't see any errors in EmbyServer logs. I open the Web interface, go to my Media, nothing happens, then F5 and Emby is no longer reachable... Not sure if it means anything, but when Emby is starting up, its showing a message, and the code-page does not seem right. Emby Server sa spúšťa. SkĂşste to prosĂm o chvĂÄľu znova. Edited January 28, 2019 by KarolKo
Luke 42217 Posted January 28, 2019 Posted January 28, 2019 I am running Emby 4.0.1.0 on FreeNAS and my server is also crashing when I try to browse my Library, via web or via Android app. Can't see any errors in EmbyServer logs. I open the Web interface, go to my Media, nothing happens, then F5 and Emby is no longer reachable... Not sure if it means anything, but when Emby is starting up, its showing a message, and the code-page does not seem right. @@KarolKo please attach the emby server log, thanks.
Luke 42217 Posted January 28, 2019 Posted January 28, 2019 @@cembry, for you as well please also attach the emby server log, thanks.
cembry 1 Posted January 28, 2019 Author Posted January 28, 2019 (edited) There is my emby server log... embyserver.txt Edited January 28, 2019 by cembry
Luke 42217 Posted January 28, 2019 Posted January 28, 2019 There is my emby server log... embyserver.txt Can you please try uninstalling these plugins: 2019-01-28 21:21:23.739 Info App: Loading playback_reporting, Version=1.2.7.0, Culture=neutral, PublicKeyToken=null from C:\Users\Kelly Taylor\AppData\Roaming\Emby-Server\programdata\plugins\playback_reporting.dll 2019-01-28 21:21:23.739 Info App: Loading statistics, Version=2.0.8.0, Culture=neutral, PublicKeyToken=null from C:\Users\Kelly Taylor\AppData\Roaming\Emby-Server\programdata\plugins\Statistics.dll Then restart the server and see if there is still an issue. Thanks.
cembry 1 Posted January 28, 2019 Author Posted January 28, 2019 I just uninstall the two plugins, restarted embyserver... Searching for Stellan or trying to show his page via link from a movie leads to server crash - embyserver.exe dissappears.
KarolKo 0 Posted January 29, 2019 Posted January 29, 2019 And here is my server.log. embyserver.log.txt
Luke 42217 Posted January 29, 2019 Posted January 29, 2019 Ok, for those of you willing to try the beta server, 4.1.0.4 has a possible fix. Thanks.
KarolKo 0 Posted January 30, 2019 Posted January 30, 2019 (edited) I am sorry to say, 4.1.0.4 did nothing for me. embyserver_4.1.0.4.txt Edited January 30, 2019 by KarolKo
denanet 7 Posted January 30, 2019 Posted January 30, 2019 For myself, I solved this problem in this way https://emby.media/community/index.php?/topic/62733-movieseriesactors-images-crashes-server/?p=693195
Luke 42217 Posted January 31, 2019 Posted January 31, 2019 We are still looking into this though so that you don't need to apply a workaround.
