njiska 8 Posted January 26, 2019 Posted January 26, 2019 Kodi Version: Leia RC5 Emby Version: 3.5.0.2 (Running on 32-bit QNAP NAS. Highest Version currently available in QNAP CLUB) Emby for Kodi Version: 4.0.1 Upgraded Kodi to Leia RC5 inorder to address a video rendering issue with my Ubuntu machine. Following the upgrade Emby for Kodi failed, so I upgraded to the beta branch; I believe it was 3.1.44a. Performed a database reset as requested by the addon. Added my libraries and began syncing. Sync worked fine until it encountered a series with a very large number of episodes (over 1500). Sync appears to get stuck on this series and then eventually times out. Error message displayed: Something went wrong during the sync. You'll be able to restore progress when Restarting Kodi. If the problem persists please report on the Emby for Kodi forums, with your Kodi log. Resuming the sync results in the same hang and the same error. Uploaded log is following a DB reset to ensure the cleanest records. https://paste.kodi.tv/hugohuhuku
Angelblue05 4132 Posted January 26, 2019 Posted January 26, 2019 Can you post your server log from that time as well. Looks like your server is crashing or simply not responding anymore, when the add-on queries the episodes for Kamen Rider.
njiska 8 Posted January 27, 2019 Author Posted January 27, 2019 Sure. https://drive.google.com/file/d/17tX5RnLy1IxrqctkpUmB5KzoBZ41QASM/view?usp=sharing I should also add, if I remove the Kamen Rider directory from Emby the scan will continue without issue until it hits my Super Sentai series entry which also has a very large number of episodes, more than the Kamen rider directory, and demonstrates a similar time out error. My other system, running Kodi 17.6 with the previous non-beta version of Emby for Kodi, continues to be able to sync these two directories, even after a DB reset.
Angelblue05 4132 Posted January 27, 2019 Posted January 27, 2019 (edited) Ok, that's because it retried until it got a response from your server.. I'll make sure it doesn't get stuck like that, but still... not normal for your server to take so long to respond either. Edited January 27, 2019 by Angelblue05
Angelblue05 4132 Posted January 27, 2019 Posted January 27, 2019 @@Luke Can you check the server log posted above. The server seems really slow to respond when querying 15 episodes from a show with a lot of episodes.
Luke 42239 Posted January 27, 2019 Posted January 27, 2019 Yea that's an area that needs to be improved. Thanks. 1
njiska 8 Posted February 18, 2019 Author Posted February 18, 2019 Just wondering if there as been any update on this. Sync still fails in the latest version of Emby for Kodi. 1
Angelblue05 4132 Posted February 22, 2019 Posted February 22, 2019 @@njiska Can you try with the latest beta version of the add-on (4.0.7a)? Let me know if it allows you to progress beyond those entries. Thank you.
njiska 8 Posted February 24, 2019 Author Posted February 24, 2019 Same results on 4.0.7a. Sits on the directory for about 10 minutes then reports something went wrong.
Angelblue05 4132 Posted February 24, 2019 Posted February 24, 2019 (edited) Can you post an updated log? Thanks. Edited February 24, 2019 by Angelblue05
njiska 8 Posted February 24, 2019 Author Posted February 24, 2019 (edited) Emby for Kodi: https://paste.kodi.tv/enepetirik Emby server: https://drive.google.com/file/d/1WDZiH702PsPukVIR3Bqvtq75UUh8u1ca/view?usp=sharing Edited February 24, 2019 by njiska 1
njiska 8 Posted March 25, 2019 Author Posted March 25, 2019 UPDATE: This never ended up working with the QNAP Club version of Emby 3.5. Last week I got feed up and took the time to remove it and install 4.0.2.0. Since doing this Kodi has been able to successfully sync the large series, though the Emby server barely responds while the initial sync occurs. 1
