Supermp3man06 2 Posted January 26, 2019 Posted January 26, 2019 (edited) Bonjour, bonsoir, je cherche un moyen de "débloqué" l'accès au dossier embyserver sur DSM via OSX, de base on ne peut pas, les dossiers système sont masqués, je ne maitrise pas encore le NAS à fond, si quelqu'un a une solution ça serait sympa. Merci. Hi i'm looking to access to the folder embyserver on DSM Synology with OSX, does anyone have a solution. Thanks. Edited January 26, 2019 by Supermp3man06
Luke 42240 Posted January 26, 2019 Posted January 26, 2019 Have you tried just entering the path into the finder tool?
Supermp3man06 2 Posted January 26, 2019 Author Posted January 26, 2019 yes but it doesn't work, DSM don't allow you by default to access the system folder, i find a solution with windows but i'm on OSX
Luke 42240 Posted January 28, 2019 Posted January 28, 2019 Ok so Emby Server is installed on Synology and you want to access from a MacOS machine? @@FrostByte have you tried this?
Supermp3man06 2 Posted January 28, 2019 Author Posted January 28, 2019 Yes, i know you can access to this folder with WinSCP on a PC, i'm sure it's possible to do the same with a Mac but i didn't find how to do it .
FrostByte 5453 Posted January 28, 2019 Posted January 28, 2019 I've used cyberduck and filezilla on my neighbors mac. Nothing that compares to how good WinSCP is though.
Supermp3man06 2 Posted January 28, 2019 Author Posted January 28, 2019 So did you success do go in this folder with FTP protocole ?? @@FrostByte
FrostByte 5453 Posted January 28, 2019 Posted January 28, 2019 Yes, we were able to navigate all Emby folders
Supermp3man06 2 Posted January 28, 2019 Author Posted January 28, 2019 I'm gonna try with my NAS. Thank you
Supermp3man06 2 Posted January 28, 2019 Author Posted January 28, 2019 I tried with ftp protocole but i can't access to the var folder. Thank you anyway for your time i will try with the synology community to find a solution.
sephrat 16 Posted May 25, 2020 Posted May 25, 2020 Je ne connais pas bien OSX mais en dernier recours il y a toujours SSH. https://www.synology.com/fr-fr/knowledgebase/DSM/tutorial/General_Setup/How_to_login_to_DSM_with_root_permission_via_SSH_Telnet
