AdrianW 1058 Posted May 1, 2014 Posted May 1, 2014 For some reason I have a "Refresh Guide" task running every 4 hours - but this task does not exist on the Scheduled Tasks page, so I can't change that schedule. I don't even have Live TV installed - so why is that task even running at all? Please also see this related post: Triggers running at wrong times
AdrianW 1058 Posted March 18, 2015 Author Posted March 18, 2015 "Refresh Guide" and "Convert media" are still running on a schedule - can we PLEASE prevent these unwanted tasks from ever running. I do not have any Live TV plugin installed and I assume "Convert media" has something to do with Sync - which is something else that I don't use. These tasks run every few hours and seem to be responsible for keeping my NUC awake. I just found "Convert media" in the "Scheduled Tasks" section - so I've disabled that one, but why doesn't "Refresh Guide" appear under Scheduled Tasks? I'd like to disable that as well.
Sven 136 Posted March 18, 2015 Posted March 18, 2015 Can you also post a log file? So we can check some stuff...
AdrianW 1058 Posted March 18, 2015 Author Posted March 18, 2015 (edited) Here's some of the relevant lines: 2015-03-17 01:43:36.1053 Info - App: IntervalTrigger fired for task: Refresh Guide 2015-03-17 01:43:36.1053 Info - App: Executing Refresh Guide 2015-03-17 01:43:36.4354 Info - App: Refresh Guide Completed after 0 minute(s) and 0 seconds 2015-03-17 01:43:36.4354 Info - ServerManager: Sending web socket message ScheduledTaskEnded 2015-03-17 02:43:36.7316 Info - App: IntervalTrigger fired for task: Convert media 2015-03-17 02:43:36.7316 Info - App: Executing Convert media 2015-03-17 02:43:36.7316 Info - App: Convert media Completed after 0 minute(s) and 0 seconds 2015-03-17 02:43:41.4220 Info - App: HttpClientManager GET: http://bot.whatismyipaddress.com/ 2015-03-17 02:43:43.1921 Info - App: HttpClientManager POST: https://connect.mediabrowser.tv/service/Servers?id=973c792841ee7afd3a372a455e430d0d 2015-03-17 02:43:43.9221 Info - App: HttpClientManager GET: https://connect.mediabrowser.tv/service/ServerAuthorizations?serverId=973c792841ee7afd3a372a455e430d0d 2015-03-17 05:43:35.7391 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3ServerNotifications.json 2015-03-17 05:43:37.6592 Info - App: IntervalTrigger fired for task: Refresh Guide 2015-03-17 05:43:37.6592 Info - App: Executing Refresh Guide 2015-03-17 05:43:37.9692 Info - App: IntervalTrigger fired for task: Convert media 2015-03-17 05:43:37.9692 Info - App: Refresh Guide Completed after 0 minute(s) and 0 seconds 2015-03-17 05:43:38.1692 Info - App: Executing Convert media 2015-03-17 05:43:38.1692 Info - App: Convert media Completed after 0 minute(s) and 0 seconds Here's the full log (21MB). Edited March 18, 2015 by AdrianW
Boredcat 34 Posted June 4, 2015 Posted June 4, 2015 I have the same issue. Refresh guide running with no LiveTV installed. 2015-06-04 18:27:55.5375 Info - App: Executing Refresh Guide Please let me know if you need the complete log. I will installed the LiveTV plugin's and see if I can remove the task and then remove the LiveTV plugin. Keep you informed.
Boredcat 34 Posted June 4, 2015 Posted June 4, 2015 Solved. Installed ServerWMC, remnoved all Guide tasks. Uninstalled ServerWMC, and Yes task isn't running anymore (was first set to run at startup)..
