UlfS 0 Posted January 25, 2019 Posted January 25, 2019 Hi, I wonder if you can tell me what is wrong when I cannot choose any hardware decoder according to attached image. brgds Ulf
Luke 42216 Posted January 25, 2019 Posted January 25, 2019 Please attach the emby server and hardware detection logs. Thanks.
UlfS 0 Posted January 26, 2019 Author Posted January 26, 2019 Sorry, here comes the image and the log. hardware_detection-63684101667.txt
PenkethBoy 2068 Posted January 26, 2019 Posted January 26, 2019 What is you server hardware? And i would upload the server log as well for Luke
UlfS 0 Posted January 26, 2019 Author Posted January 26, 2019 I am running Windows Server 2016 on an ASUS board (Asus Z87 Pro) which has an integrated Intel HD graphics 4600 chip. Also attaching server logs. embyserver.txt
PenkethBoy 2068 Posted January 26, 2019 Posted January 26, 2019 do you have intel drivers loaded for the cpu's gpu? do you have a monitor attached to the motherboard hdmi output (monitor does not need to be on just connected) if the iGPU enabled in the bios - Z87 is quite an old m/b but i have a z87 with i7 4790s cpu on 2012r2 - with intel drivers and it works fine with Emby
Luke 42216 Posted January 26, 2019 Posted January 26, 2019 Also also make sure the drivers are up to date. thanks.
