cfuson 0 Posted February 3, 2019 Author Posted February 3, 2019 (edited) I enabled debugging before doing the previous post I Edited February 3, 2019 by cfuson
snazy2000 345 Posted February 3, 2019 Posted February 3, 2019 I enabled debugging before doing the previous post I Looks like that log is from 1st Feb Sent from my iPhone using Tapatalk
cfuson 0 Posted February 3, 2019 Author Posted February 3, 2019 Here are current ones - Also I turned off the firewall on the server just to make sure it was not interfering embyserver.txt hardware_detection-63684777396.txt
snazy2000 345 Posted February 3, 2019 Posted February 3, 2019 Here are current ones - Also I turned off the firewall on the server just to make sure it was not interfering Looking quickly at logs (on phone) i can see 2019-02-03 07:57:31.954 Error HttpClient: Connection to http://192.168.80.7:54479/data/data.xml timed out Is your playon server running ? Can you access that address from your emby server? Ill take better look at log later when at PC, PM me will be easier Sent from my iPhone using Tapatalk
cfuson 0 Posted February 3, 2019 Author Posted February 3, 2019 Shut down server deleted log folder restarted server access from server - playon still no icons Logs attached embyserver.txt hardware_detection-63684779151.txt
cfuson 0 Posted February 3, 2019 Author Posted February 3, 2019 OK -it took me a minute, but I see what you were saying about playon server not connecting.- Sorry I installed playon on the same machine as emby server reconfigured plugin to local sereverr turned on debugging shut server down deleted cache and log folders started emby server tried to access playon live tv same issue new logs attached embyserver.txt hardware_detection-63684779934.txt
Azzablitz 1 Posted March 3, 2019 Posted March 3, 2019 Hi cfusion just wondering how you ended up with your issue. I have been busy and not been using playon. I still have issues and i know snazy2000 like a PM to fix issues, thought you may have sorted with him. If not i'll get back to him with mine. Thanks
cfuson 0 Posted March 3, 2019 Author Posted March 3, 2019 Issues have not been resolved. He is getting with the Emby foWindows 10 lks as it appears to be an issue with Emby and not the plugin. We did find that if you use IE and go to ALL to get to live tv instead - you will see multiple icons, go thru them and you can find one that works. This is true for the Roku app and WindowsTheater app.
