cfuson 0 Posted January 25, 2019 Posted January 25, 2019 Version after 3.5.3.0 causes the playon plugin to stop working properly. I get several icons for live tv, only 1 of which will work and when you start watching a tv channel it will only play for a couple minutes then you get a black screen - no sound or video and the links at the top for going back or home disappear. I reverted back to 3.5.3.0 and all is working again.
Luke 42255 Posted January 25, 2019 Posted January 25, 2019 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
Luke 42255 Posted January 25, 2019 Posted January 25, 2019 There's a large number of log files here. is there a specific example we can look at? Thanks !
cfuson 0 Posted January 25, 2019 Author Posted January 25, 2019 didn't know which log you needed so I sent the entire folder :\
Luke 42255 Posted January 26, 2019 Posted January 26, 2019 I'll need the developer @@snazy2000 to confirm that he's tested the plugin on the 4.0 server. Thanks.
Azzablitz 1 Posted January 26, 2019 Posted January 26, 2019 (edited) I am experiencing the same issues. All clients show multiple icons in Playon since V4 and playback doesn't work on Win 10 boxes, however the Ipad does work it just takes longer to see the playback then usual. If you need more logs then what @cfusion has supplied happy to post more to assist in troubleshooting. Thanks. @@snazy2000 here are my server logs and a screen shot hope they help. embyserver.txt Edited January 26, 2019 by Azzablitz
snazy2000 345 Posted January 26, 2019 Posted January 26, 2019 I will take a look at this asap Sent from my iPhone using Tapatalk 1
snazy2000 345 Posted January 26, 2019 Posted January 26, 2019 I have just pushed and update, all seems to be working for me now on V4, if you have any issues PM me with debug logging on and attach the log file Thanks 1
cfuson 0 Posted January 26, 2019 Author Posted January 26, 2019 do I just go to downloads to get it? my system is not showing an update
cfuson 0 Posted January 28, 2019 Author Posted January 28, 2019 A new version of the Playon plugin loaded and now I get a blank screen when I click on "Live TV". I shut down emby, removed the cache folder, shut down playon and removed the cache folder there as well. I started Playon, then I started Emby and get the same resault, Attached is the server log file embyserver.txt
Luke 42255 Posted January 28, 2019 Posted January 28, 2019 Ok, we'll see what @@snazy2000 thinks. Thanks.
cfuson 0 Posted January 31, 2019 Author Posted January 31, 2019 Curious if you came up with anything as of yet?
Luke 42255 Posted January 31, 2019 Posted January 31, 2019 try deleting these folders: C:\Users\Chris\AppData\Roaming\Emby-Server\programdata\channels C:\Users\Chris\AppData\Roaming\Emby-Server\programdata\httpclient
cfuson 0 Posted January 31, 2019 Author Posted January 31, 2019 I found the folders under cache so I deleted C:\Users\Chris\AppData\Roaming\Emby-Server\programdata\cache\channels and C:\Users\Chris\AppData\Roaming\Emby-Server\programdata\cache\httpclient Still nothing
Luke 42255 Posted January 31, 2019 Posted January 31, 2019 Can you please attach the emby server log? Thanks.
cfuson 0 Posted January 31, 2019 Author Posted January 31, 2019 Ok - I set up a new server and installed emby and playon on it. It did not help - same issue. I did notice that if you goto PlayOn/All * you get multiple icons for the channels * I click on the 2nd icon for Spectrum * Click on Live TV ** I can now see the icons for the channels (only one per channel) ** I click on one to open it - I see the swirling "waiting" thing ** it then errors off with the playback error "No Compatible Streams....." Attached is the server log and some screen shots embyserver.txt
Luke 42255 Posted February 1, 2019 Posted February 1, 2019 Was an ffmpeg log generated? Can you provide that as well? thanks.
cfuson 0 Posted February 1, 2019 Author Posted February 1, 2019 I deleted all the logs and restarted the server to create new logs. I tried the playon tv and no ffmpeg log was created. attached is the only logs created embyserver.txt hardware_detection-63684631556.txt
snazy2000 345 Posted February 3, 2019 Posted February 3, 2019 Hey, can you turn debug logging on and repo again please. When you get two options do you click on both of them as it tends to be the second one that has content and first one appears blank Sent from my iPhone using Tapatalk
cfuson 0 Posted February 3, 2019 Author Posted February 3, 2019 Here is what I did Shutdown Emby Server Deleted Cache and log folders first I click on Playon then Live TV - No Icons Then I hit back and clicked on ALL - now I don't get any icons ALL Logs attached embyserver.txt hardware_detection-63684777396.txt
snazy2000 345 Posted February 3, 2019 Posted February 3, 2019 Here is what I did Shutdown Emby Server Deleted Cache and log folders first I click on Playon then Live TV - No Icons Then I hit back and clicked on ALL - now I don't get any icons ALL Logs attached That log doesn’t have debug logging enabled, can you please enable and re run test (then disable after) Sent from my iPhone using Tapatalk
