parrotheadcubs 9 Posted May 1, 2014 Posted May 1, 2014 Great service first of all. This may be dumb but am I able to access my content when I'm not connected to my network? Like will the iOS apps work if I'm away from home? Or do I access that through the web like I setup on the xbox one through internet explorer. Thanks.
swhitmore 781 Posted May 1, 2014 Posted May 1, 2014 (edited) Hey, welcome to the community! You can definetly access everything outside of your home network. Have a look at this knowledge base article. Hopefully it contains everything you need. If you get stuck, let me know. Edited May 1, 2014 by swhitmore
parrotheadcubs 9 Posted May 1, 2014 Author Posted May 1, 2014 Well I am putting in the address correctly. The right IP address and Port number and it's coming up as problem loading the page. Thoughts?
parrotheadcubs 9 Posted May 1, 2014 Author Posted May 1, 2014 No, because I'm an idiot. I'll do it at lunch. Thanks.
parrotheadcubs 9 Posted May 1, 2014 Author Posted May 1, 2014 Alright I did the port forwarding. Created MB3 and pointed it to the IP address of the server. Port of 8096 for both. I go to what I think should be the site, http://ip address:8096/mediabrowser and still page not found.
parrotheadcubs 9 Posted May 1, 2014 Author Posted May 1, 2014 Wow, I'm an idiot. So I went to the remote access and got right in. I'm so stupid.
ebr 16337 Posted May 2, 2014 Posted May 2, 2014 You just need to use the external IP address of your router. Then the port forwarding you setup will handle getting the traffic to the MB machine. 1
parrotheadcubs 9 Posted May 2, 2014 Author Posted May 2, 2014 Yep. I'm in it right now. That was easy! 1
chef 3811 Posted May 2, 2014 Posted May 2, 2014 (edited) Perhaps try adding "dashboard\index.htm" at the end of what you wrote above?? Http:\\{ip}:{port}\mediabrowser\dashboard\index.htm Edited May 1, 2014 by chef
parrotheadcubs 9 Posted May 2, 2014 Author Posted May 2, 2014 Shouldn't be. I'm running Microsoft Security Essentials.
ebr 16337 Posted May 2, 2014 Posted May 2, 2014 Well, did you allow traffic both ways for the server application on the server machine?
parrotheadcubs 9 Posted May 2, 2014 Author Posted May 2, 2014 I may have found that I'm trying to send it to an IP address that I can't use. Sounds like I need DNS?
parrotheadcubs 9 Posted May 2, 2014 Author Posted May 2, 2014 Basically I have a non routable IP address that can't be accessed. A 192.168. Frankly I'm not savvy enough to know how to work around this.
swhitmore 781 Posted May 2, 2014 Posted May 2, 2014 (edited) If you have a dynamic ip address (external), I recommend using a DNS, otherwise it will stop working everytime your external IP address changes. I use no-ip (free). Edited May 2, 2014 by swhitmore 1
Luke 42244 Posted May 2, 2014 Posted May 2, 2014 where did you get the address from? did you try the one listed on the main page of the server dashboard?
swhitmore 781 Posted May 2, 2014 Posted May 2, 2014 where did you get the address from? did you try the one listed on the main page of the server dashboard? I think in the end he did.
parrotheadcubs 9 Posted May 2, 2014 Author Posted May 2, 2014 Yes that's the one I used. Should I go a different route?
ebr 16337 Posted May 2, 2014 Posted May 2, 2014 Yes that's the one I used. Should I go a different route? No, that's correct. You've got it now.
parrotheadcubs 9 Posted May 2, 2014 Author Posted May 2, 2014 Except that now it won't load. Problem loading page.
parrotheadcubs 9 Posted May 2, 2014 Author Posted May 2, 2014 Well my remote address changed that's why I couldn't access it. Looks like I'll have to go through something like noip.com to combat this moving forward. 1
swhitmore 781 Posted May 3, 2014 Posted May 3, 2014 Well my remote address changed that's why I couldn't access it. Looks like I'll have to go through something like noip.com to combat this moving forward. Yeah, that's why I suggested using a DNS . Every time your external IP changes it will break. Using a DNS like no-ip will solve your issue. 1
