Angelblue05 4132 Posted January 27, 2019 Posted January 27, 2019 What is your server platform @@zMeckx
Angelblue05 4132 Posted January 27, 2019 Posted January 27, 2019 (edited) I've got it working and weird enough it's a little thing. Not working: .mkv .dutch.forced.srt Working: .mkv .Dutch.forced.srt // It only works for me with capitalizing the language, can you try the same? Or does it also works on your end with all lowercase letters? Synology. @@Luke Is this something you are aware of? I do not see a difference, but I'm using Windows. Edited January 27, 2019 by Angelblue05 1
Luke 42239 Posted January 27, 2019 Posted January 27, 2019 Casing won't matter, however for best results i would use the two or three character code for the language. 2
zMeckx 9 Posted January 27, 2019 Author Posted January 27, 2019 (edited) Casing won't matter, however for best results i would use the two or three character code for the language. @@Luke Thanks for the response. I tried it but it doesn't make any difference.. http://prntscr.com/mczhvq Library settings: http://prntscr.com/mczirf File names: http://prntscr.com/mczj75 Edited January 27, 2019 by zMeckx
Luke 42239 Posted January 28, 2019 Posted January 28, 2019 Make sure to run a library scan after renaming.
zMeckx 9 Posted January 28, 2019 Author Posted January 28, 2019 (edited) @@Luke I did that, but no results. Edited January 28, 2019 by zMeckx
Angelblue05 4132 Posted January 28, 2019 Posted January 28, 2019 (edited) @@zMeckx Isn't it better to use "nl" instead of "Dut"? https://kodi.wiki/view/List_of_language_codes_(ISO-639:1988) Edited January 28, 2019 by Angelblue05 1
zMeckx 9 Posted January 28, 2019 Author Posted January 28, 2019 @@zMeckx Isn't it better to use "nl" instead of "Dut"? https://kodi.wiki/view/List_of_language_codes_(ISO-639:1988) @Angelblue05 I tried it with Flicka Country Pride (2012).nl.srt Flicka Country Pride (2012).nl.forced.srt It recognizes the subtitle as shown in the screenshots above but he always pick the English Default: http://prntscr.com/md4yvs 1
Angelblue05 4132 Posted January 28, 2019 Posted January 28, 2019 (edited) Can you provide a screenshot of the media info from the emby webclient with the nl naming? Thank you Edited January 28, 2019 by Angelblue05
daedalus 434 Posted January 28, 2019 Posted January 28, 2019 It recognizes the subtitle as shown in the screenshots above but he always pick the English Default: http://prntscr.com/md4yvs emby saves the stream selection, so it will always play the last selected streams again 2
Angelblue05 4132 Posted January 28, 2019 Posted January 28, 2019 emby saves the stream selection, so it will always play the last selected streams again This is very true. @@zMeckx Do you see the second track in Kodi with nl? If so, try selecting the subtitles. Wait a few moments. Stop playback. Start playback, it should pick the correct subtitles. 1
Solution zMeckx 9 Posted January 28, 2019 Author Solution Posted January 28, 2019 (edited) emby saves the stream selection, so it will always play the last selected streams again Wow, yeah that's it! This is very true. @@zMeckx Do you see the second track in Kodi with nl? If so, try selecting the subtitles. Wait a few moments. Stop playback. Start playback, it should pick the correct subtitles. Yeah it works now. Pffff Thanks for the great support Edited January 28, 2019 by zMeckx 1
