kuebs 6 Posted January 24, 2019 Posted January 24, 2019 Hello all. There was recently a new version of Emby which seems to have changed how videos, specifically TV show episodes are tracked and displayed. I used to just get the season for latest video, if I put more than one episode in the folder. Now it shows the season, and each episode, and sometimes the series as a separate item in the folder. I want it to go back to just the season or the episode. What changed? What setting do I need to adjust, Thank you.
Luke 42219 Posted January 24, 2019 Posted January 24, 2019 Hi there, can you please go over an example? thanks.
kuebs 6 Posted January 25, 2019 Author Posted January 25, 2019 OK. Well I have The Passage Episode 1 and Episode 2. It has both of those listed under latest, but also, the season and a separate tile for the series.
Luke 42219 Posted January 25, 2019 Posted January 25, 2019 Sorry I'm having a hard time following. Can you show screenshots to demonstrate the issue? Thanks !
kuebs 6 Posted August 1, 2019 Author Posted August 1, 2019 I just gave up and deleted all the series in question. These problems are happening more and more, with no solution, but start over.
Luke 42219 Posted August 1, 2019 Posted August 1, 2019 Can you show screenshots to demonstrate the issue?
