HumanPanda 6 Posted May 1, 2014 Posted May 1, 2014 I have 3 issues so far with the app that aren't really big but I feel could be able to fixed easily. - I have media browser to require mandatory login but any user I do not specifically hide is still shown. I found out this bug because I have an account to use with MBClassic as that one doesn't have any manual entry - If you have a saved connection 1,2 or more you can't add a new connection or select a different connection. As I don't have 2 servers I'm not sure which one it asking you to connect to. - Manual entry doesn't have a remember me while if they are unhidden there is a remember me check box. It gets annoying to always have to enter username and password especially since they are hidden. Not really an issue more of a question. Why is chromecast limited to 6mbps? Otherwise great app especially for 99c. Thanks for the sale and your amazing work. If you do decide to fix this hope it doesn't detract too much from you working on Live TV.
