freeflight29 2 Posted January 24, 2019 Posted January 24, 2019 (edited) Hello, my web interface was not reachable (i don't know since when cause i use emby on two nas , and on the other everything is fine) -Nas : as6404T with latest firmware 3.2.5.RPE8 -emby: 4.0.1.0 So i decided to uninstall emby and reinstall It = KO I also try to reinstall connecting via ssh , i delete 2 folders /volume1/home/embyand /volume1/.@plugins/AppCentral/emby-server and then reinstall the package = KO i see that /volume1/home/emby was not created automatically so i created via shh = KO (via asustor web interface it's asking for a password) Nothing is working. i need some help Thank you Edited January 24, 2019 by freeflight29
Luke 42237 Posted January 24, 2019 Posted January 24, 2019 I would try rebooting the Nas and then installing emby again. Thanks.
freeflight29 2 Posted January 24, 2019 Author Posted January 24, 2019 I would try rebooting the Nas and then installing emby again. Thanks.Unfortunately already done, but not working
freeflight29 2 Posted January 24, 2019 Author Posted January 24, 2019 I uninstalled it by asustor interface Then I connected on the server via ssh I saw the folder /volume1/.@plugins/AppCentral/emby-server Was correctly deleted I erase the content of "emby" user's folder I reinstall emby via asustor package. I restarted the nas and launch emby via asustor desktop emby icon But not working
Luke 42237 Posted January 24, 2019 Posted January 24, 2019 That's just strange because asustor tested this themselves and certified it. can you locate an emby server log? thanks.
freeflight29 2 Posted January 24, 2019 Author Posted January 24, 2019 I'm not front of my pc by now, but I saw a logs folder under emby user folder. I will confirm you that.
freeflight29 2 Posted January 24, 2019 Author Posted January 24, 2019 (edited) here logs from /volume1/home/emby/logs logs.zip Edited January 24, 2019 by freeflight29
Luke 42237 Posted January 24, 2019 Posted January 24, 2019 It looks like the server is running and serving requests. what happens if you put this url in a browser: http://192.168.0.100:8096
freeflight29 2 Posted January 24, 2019 Author Posted January 24, 2019 (edited) omg.... i think i just fogot to reinstall emby with the local IP, i just use my usual shortcut !!!!! sorry Luke !!! i will reinstall emby and let you know. Edited January 24, 2019 by freeflight29
Luke 42237 Posted January 24, 2019 Posted January 24, 2019 reinstall emby with the local IP, What does that mean exactly?
freeflight29 2 Posted January 24, 2019 Author Posted January 24, 2019 I type http://192.168.0.100:8096 and I arrive on emby start wizard menu. It's because I delete before the emby user folder, I suppose
freeflight29 2 Posted January 24, 2019 Author Posted January 24, 2019 Sorry to use your time for that.... Thanks for your help
