medric 5 Posted January 24, 2019 Posted January 24, 2019 Auto Box Set collections use to show up under movies at a box set now they show as individual files. I still have a collections tab at the top but when you go to your library it shows all files and does not show any box set / collections in that folder
Solution ebr 16344 Posted January 24, 2019 Solution Posted January 24, 2019 Hi. This has moved to a view-level setting. The Announcement mentioned this. Thanks.
