jimj 0 Posted January 23, 2019 Posted January 23, 2019 Within the last week when I scan the Movies library it now takes 21 minutes to complete and the CPU is pegged at 98%. The TV shows library completes in about 15 seconds. When I scan the Movies library it goes from 0 to 90% complete in one second then increments 1% every 2 minutes or so until 100%. I haven't added anything new to the library today and running pretty much default settings for everything. Have been using for several months for zero issues. I have 2,123 movies on a Synology NAS. Have restarted several times and just installed the latest version this morning. Thanks
Luke 42239 Posted January 23, 2019 Posted January 23, 2019 Hi there, can you please attach the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
jimj 0 Posted January 23, 2019 Author Posted January 23, 2019 Sorry I thought I had included the server log. Also running Version 10.14.2 on OS X embyserver.txt
Luke 42239 Posted January 24, 2019 Posted January 24, 2019 Hi @@jimj, are you sure this is the right one? This log does not contain a library scan. Thanks !
jimj 0 Posted January 24, 2019 Author Posted January 24, 2019 I am possibly an idiot, but I am looking at the current library scan with debugging which I started at Jan 24 @ 08:26 and ended at 08:47. I am getting this from the Emby logs area and the file is called embyserver.txt 1/24/2019 8:53am Am I doing something wrong? Debug.txt
Luke 42239 Posted January 28, 2019 Posted January 28, 2019 @@jimj, That log looks OK to me. The scan took 20 minutes. We are looking into improving it. Thanks.
jimj 0 Posted January 28, 2019 Author Posted January 28, 2019 The scan used to take 90 seconds, and still does scan TV series is 90 seconds. Movies is now taking 20 minutes and pegging the CPU. Never done that before.
Spaceboy 2573 Posted January 29, 2019 Posted January 29, 2019 The scan used to take 90 seconds, and still does scan TV series is 90 seconds. Movies is now taking 20 minutes and pegging the CPU. Never done that before.that word means something different in the UK [emoji23]
