rms8 14 Posted January 22, 2019 Posted January 22, 2019 (edited) Use the release channel you prefer. Both will get the updates. Thanks. EMC is currently on v3.0.317.0 Emby Server is on v4.0.1.0 Appears my MOVIES and Documentaries are back to normal !!!!!!!!!! When I go to Music, however; it's still the same odd behavior. Something else I noticed is at some point during this debacle several theme-plugins were removed from my EMC. Namely Destiny (since that's the one I always use) and Supremacy. I have since added those back in (hope it didn't charge me since I already paid for them in the past) Here you can see that my MOVIES is look normal again ! But not ALL is back to normal. For instance my MUSIC is still messed up. It almost appears as if it is behaving like Music Genres instead ???? Then when I actually go into MUSIC, instead of displaying all of my CD's, it shows what again appears to be a Genres instead: CONCERTS on the EHS is also behaving bad : STANDUP is working NORMAL though : FORECAST remains blank: So it looks like MOVIES, DOCUMENTARIES and STANDUP are now working as expected/normal again, but not all the items are back to normal (like MUSIC, FORECAST, CONCERTS....). On a side note, how do I edit the EHS to remove "Playlists" ? Edited January 22, 2019 by rms8
rms8 14 Posted January 22, 2019 Author Posted January 22, 2019 Just added pics to better describe the current situation.......see above
Luke 42237 Posted January 22, 2019 Posted January 22, 2019 @@Happy2Play can you please move his post to the emc section? Thanks.
rms8 14 Posted January 22, 2019 Author Posted January 22, 2019 I saw that someone was using a newer version of the Server SW. It was a Beta. Should I try that one? Think it was v4.1
Luke 42237 Posted January 22, 2019 Posted January 22, 2019 Let's get our topic moved to the EMC section where it will be easier to follow and then we'll go from there. Thanks.
ebr 16331 Posted January 22, 2019 Posted January 22, 2019 @@Happy2Play can you please move his post to the emc section? Thanks. This topic was not originally related to EMC. It was just mixed content in the server. It is only the later posts that are EMC specific.
Luke 42237 Posted January 22, 2019 Posted January 22, 2019 Ok, I'm just having a hard time following when it's report embedded into another topic. Thanks.
Luke 42237 Posted January 23, 2019 Posted January 23, 2019 Does your music look normal in the web app?
