outlaw69uk 7 Posted January 22, 2019 Posted January 22, 2019 Hey guys, Just updated to the latest version. Collections are k my showing in libraries designated movies. I have multiple genre based libraries, using mixed content as a type. Folder structure is (as an example) Horror /horror/films /horror/tv The tv shows are fine, it also automatically finds all the films, but, won't organise them into collections, which it always used to do. It's definitely a pain I sci-fi and horror, as I have a ton of multi film series, like elm street, or alien. The extras folders seem to work fine too When I choose add to collection, the option is prefilled for most of these, but, in the view option it's not available (the show collections tickbox) Am I doing something dumb?
Luke 42216 Posted January 22, 2019 Posted January 22, 2019 Hi there, how did you create the collections?
outlaw69uk 7 Posted January 22, 2019 Author Posted January 22, 2019 Hi there, how did you create the collections? I generally used the auto collection plugin. Or, right click on the film and choose add to collection
outlaw69uk 7 Posted January 22, 2019 Author Posted January 22, 2019 I should add, they show in the collections library, just not in the library that the originals are in Whn I go to the 3 dots in the main folder (ie horror/films) it only gives me the option to choose image type. In the main movies folder, there is another option there to show movies in collections
Happy2Play 9806 Posted January 22, 2019 Posted January 22, 2019 (edited) I should add, they show in the collections library, just not in the library that the originals are in Whn I go to the 3 dots in the main folder (ie horror/films) it only gives me the option to choose image type. In the main movies folder, there is another option there to show movies in collections Has there ever been group into collections for Mixed Content? Edited January 22, 2019 by Happy2Play
outlaw69uk 7 Posted January 22, 2019 Author Posted January 22, 2019 (edited) Has there ever been group into collections for Mixed Content?I am yes, sorry I thought I had said that originally. It only stopped working when I upgraded to version 4, was fine (in fact brilliant) before that As long as in the main folder I had two folders, one called films, one called tv. It seemed to recognise the type by that, and it automatically put the films in collections, with the metadata from the online sources Edited January 22, 2019 by outlaw69uk
Luke 42216 Posted January 22, 2019 Posted January 22, 2019 Right ok yes, this option is not available in mixed content libraries right now. Thanks.
outlaw69uk 7 Posted January 22, 2019 Author Posted January 22, 2019 Right ok yes, this option is not available in mixed content libraries right now. Thanks. Ah ok, no worries. It was in version 3 wasn't it? I didn't dream that?
