Library tread has exited
Hello
I setup a kodi windows client with embycon and embuary and it worked fine for a week.
When I launch kodi now it askes for my login again for some reason. I checked the embycon settings its still in there.
2 seconds later I get the error "emby for kodi Library sync tread has exited"
log file attached
kodi.txt
Please repair your TV show database. That should be enough.
I did the reïnitialize the local kodi database under the avanced options for emby but its still thesame thing.
And I should go to bed, because I haven't noticed that you are still using the stable version of the addon. Please update to the beta version, which is required for Emby 4 and reset your database again.
Sorry for the confusion.
Guest
