kikinjo 294 Posted January 22, 2019 Posted January 22, 2019 Hi all, here are my issues after upgrade from 3.5 stable to 4.02..and yesterday to 4.01 stable. 1. Mixed mode content (1 movie in sub folder, other movies in folder containg the subfolder: -. Scanning of 1 new movie takes like 5-15 minutes, and in 90% movie is not completely scanned, there is a record but no images and metadata. U need to manualy identify to complete. 2. Multi version movies (in dedicated folder): - Scanned ok sometimes, mainly not scanned at all - When scanned successfully - that movie is not longer in movie collections (this was reported several times). using autoboxsets plugin for collections 3. Multi version movies - No way to download subtitle for specific version 720p for example, gui offers only 1 version of movie to search for subs 4. Movie library Scanning - movies are scanned like 4-5X more time than on 3.5 log in attach cheers logemby.txt
kikinjo 294 Posted January 22, 2019 Author Posted January 22, 2019 Added now 4 new movies .... And hanging for 20 minutes on 91 % now, no similar issues with tv shows..only movies. On 3.5 adding 4 movies and scanning them took like max 10 seconds so if u ask me there is definitely something wrong in movies scanning in v4. Cheers
Luke 42216 Posted January 22, 2019 Posted January 22, 2019 Hi there, can you please go over some examples? Thanks.
kikinjo 294 Posted January 22, 2019 Author Posted January 22, 2019 Hey Luke, i attached log, movie is Bohemian R. I can generate more logs / scan if needed. Cheers
kikinjo 294 Posted January 22, 2019 Author Posted January 22, 2019 @@Luke i Catched this from the log, think might be useful : 2019-01-22 17:18:17.269 Info HttpServer: HTTP Response 204 to 10.8.0.2. Time: 1ms. http://10.8.0.1:8096/emby/Items/4514ec850e5ad0c47b58444e17b6346c/Refresh?Recursive=true&ImageRefreshMode=Default&MetadataRefreshMode=Default&ReplaceAllImages=false&ReplaceAllMetadata=false2019-01-22 17:18:28.111 Info App: Removing virtual season Cosmos (2014) null2019-01-22 17:18:28.111 Info App: Deleting item, Type: Season, Name: Season Unknown, Path: , Id: 1698902019-01-22 17:18:28.494 Info App: Creating Season Season Unknown entry for Cosmos (2014)2019-01-22 17:18:28.570 Info App: Removing virtual season Cosmos (2014) null2019-01-22 17:18:28.570 Info App: Deleting item, Type: Season, Name: Season Unknown, Path: , Id: 1699052019-01-22 17:18:28.600 Info App: Creating Season Season Unknown entry for Cosmos (2014)2019-01-22 17:18:28.622 Debug MediaEncoder: Ffprobe -i file:"/home/xbmc/zroot/teve/The Purge/The.Purge.S01E01.PROPER.What.is.America.720p.AMZN.WEB-DL.DDP5.1.H.264-KiNGS.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data2019-01-22 17:18:28.622 Info MediaEncoder: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -i file:"/home/xbmc/zroot/teve/The Purge/The.Purge.S01E01.PROPER.What.is.America.720p.AMZN.WEB-DL.DDP5.1.H.264-KiNGS.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data2019-01-22 17:18:28.668 Info MediaEncoder: ProcessRun 'ffprobe' Started.2019-01-22 17:18:28.747 Info MediaEncoder: ProcessRun 'ffprobe' Process exited with code 12019-01-22 17:18:28.749 Error App: Error in ffprobe *** Error Report *** Version: 4.0.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 12 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Exception: System.Exception: ffprobe failed for file:"/home/xbmc/zroot/teve/The Purge/The.Purge.S01E01.PROPER.What.is.America.720p.AMZN.WEB-DL.DDP5.1.H.264-KiNGS.mkv" - streams and format are both null: { } ffprobe version 4.0.2-emby_2018_12_09 Copyright (c) 2007-2018 the FFmpeg developers built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) configuration: --cc=x86_64-pc-linux-gnu-gcc --arch=x86_64 --prefix=/home/embybuilder/Buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-doc --disable-ffplay --disable-vdpau --disable-xlib --enable-fontconfig --enable-gnutls --enable-gpl --enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --enable-libsmbclient --enable-cuda --enable-cuvid --enable-libmfx --enable-nvenc --enable-vaapi --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --extra-libs='-lexpat -lfreetype -lfribidi -lfontconfig -liconv -lpng -lz -lvorbis -logg -lnettle -lhogweed -lgmp -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -ldl -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -luuid -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-static libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 [matroska,webm @ 0x954740] Format matroska,webm detected only with low score of 1, misdetection possible! [matroska,webm @ 0x954740] Read error at pos. 1 (0x1) [matroska,webm @ 0x954740] EBML header parsing failed file:/home/xbmc/zroot/teve/The Purge/The.Purge.S01E01.PROPER.What.is.America.720p.AMZN.WEB-DL.DDP5.1.H.264-KiNGS.mkv: Invalid data found when processing input at Emby.Server.MediaEncoding.Encoder.MediaEncoder.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo.ProbeVideo[T](T item, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.RunCustomProvider(ICustomMetadataProvider`1 provider, TItemType item, String logName, MetadataRefreshOptions options, RefreshResult refreshResult, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() at Emby.Server.MediaEncoding.Encoder.MediaEncoder.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo.ProbeVideo[T](T item, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.RunCustomProvider(ICustomMetadataProvider`1 provider, TItemType item, String logName, MetadataRefreshOptions options, RefreshResult refreshResult, CancellationToken cancellationToken) 2019-01-22 17:18:32.835 Info App: Removing virtual season Guerrilla null2019-01-22 17:18:32.835 Info App: Deleting item, Type: Season, Name: Season Unknown, Path: , Id: 1698922019-01-22 17:18:32.865 Info App: Creating Season Season Unknown entry for Guerrilla2019-01-22 17:18:32.870 Info App: Removing virtual season Guerrilla null2019-01-22 17:18:32.870 Info App: Deleting item, Type: Season, Name: Season Unknown, Path: , Id: 1699072019-01-22 17:18:32.898 Info App: Creating Season Season Unknown entry for Guerrilla2019-01-22 17:18:49.724 Info App: Removing virtual season Galapagos null2019-01-22 17:18:49.724 Info App: Deleting item, Type: Season, Name: Season Unknown, Path: , Id: 1698962019-01-22 17:18:49.753 Info App: Creating Season Season Unknown entry for Galapagos2019-01-22 17:18:49.758 Info App: Removing virtual season Galapagos null2019-01-22 17:18:49.758 Info App: Deleting item, Type: Season, Name: Season Unknown, Path: , Id: 1699092019-01-22 17:18:49.786 Info App: Creating Season Season Unknown entry for Galapagos2019-01-22 17:18:49.892 Info App: Removing virtual season The Pacific null2019-01-22 17:18:49.892 Info App: Deleting item, Type: Season, Name: Season Unknown, Path: , Id: 1698982019-01-22 17:18:49.921 Info App: Creating Season Season Unknown entry for The Pacific2019-01-22 17:18:49.927 Info App: Removing virtual season The Pacific null2019-01-22 17:18:49.927 Info App: Deleting item, Type: Season, Name: Season Unknown, Path: , Id: 1699112019-01-22 17:18:49.955 Info App: Creating Season Season Unknown entry for The Pacific2019-01-22 17:18:52.344 Info App: Removing virtual season Band of Brothers null2019-01-22 17:18:52.344 Info App: Deleting item, Type: Season, Name: Season Unknown, Path: , Id: 1699012019-01-22 17:18:52.373 Info App: Creating Season Season Unknown entry for Band of Brothers2019-01-22 17:18:52.380 Info App: Removing virtual season Band of Brothers null2019-01-22 17:18:52.380 Info App: Deleting item, Type: Season, Name: Season Unknown, Path: , Id: 1699132019-01-22 17:18:52.726 Info App: Creating Season Season Unknown entry for Band of Brothers2019-01-22 17:19:16.305 Info App: Creating Season Season Unknown entry for Bull (2016)
Luke 42216 Posted January 23, 2019 Posted January 23, 2019 Can you go over an example of something you had to manually identify? This is most likely fixed in 4.0.1. Thanks.
kikinjo 294 Posted January 24, 2019 Author Posted January 24, 2019 I had to identify every new movie i added after V4 upgrade and V4.01. Every single one. This is V4.0.1 version i put logs.
Luke 42216 Posted January 24, 2019 Posted January 24, 2019 That's normal if those movies were already in the 4.0 library. 4.0.1 will not force a refresh, but it will do better with new titles added going forward. Thanks.
