Xpenology Emby Hardware acceleration on J3455-itx iGPU
asrock j3455 - itx
DS918+ 6.2.1
jun 1.0.4b Loader
Hardware acceleration cannot find content after 4.0 update,I'm sure my CPU supports hardware acceleration,And I'm also a valid Emby Premiere.
Under 3.5, I can actually see the selected project, although it doesn't work no matter how I configure it. But in 4.0, I couldn't even see the hardware acceleration options available.
Please forgive me for using the translation software.
Edited by 6613974
@@solabc16
Thank you very much for your help。
I got this hint
Upload completed successfully, please include this filename with your ticket...
sendlogs_NAS_synology_apollolake_918+_20190122T115201UTC.tgz
Has the log been submitted?
Hello @@6613974
That's great thanks, I will have a look at the logs a little later today and get back to you.
Best
- James
  • 3 weeks later...
@@solabc16 I have same problem with @@6613974
How should I do?
I've send log
sendlogs_kunlun_server_synology_apollolake_918+_20190209T094728UTC.tgz
Edited by muztag
Hello @@muztag
Thanks for the logs, I'll take a look and get back to you - but this will almost certainly be an issue with the XPEnology instance not activating the GPU device.
Best
- James
Guest
