BlazedMonkey 112 Posted January 21, 2019 Posted January 21, 2019 Title pretty much says it all. Like most of us, when I'm watching some porn, I jump to the parts I want to watch, and turn it off when I'm "done". Unfortunately, because the video is only part-way through 'playing the movie', it keeps popping up on my home screen under the Continue Watching section. The only way to remove it is to mark the file as watched. Is there a way to simply exclude a library from showing up in Continue Watching? It is a separate library from my Movies and TV Shows libraries, but for the life of me I can't find a way to exclude it that actually WORKS! I've tried going into Settings -> Home Screen -> and unchecking the box that says "Display in home screen sections such as latest media and continue watching" for that library, but this doesn't actually work, it still shows half watched movies. Watching on Roku Premiere, server installed on Windows 10 running Emby Version 4.0.0.2
Happy2Play 9811 Posted January 21, 2019 Posted January 21, 2019 (edited) @@BlazedMonkey Have you looked at the Server Home Screen setting? Web client-user icon-Home Screen-Scroll down to your special library and look at "Display in home screen sections such as latest media and continue watching" Don't believe this is a Roku app issue. Edited January 21, 2019 by Happy2Play
BlazedMonkey 112 Posted January 21, 2019 Author Posted January 21, 2019 (edited) Hi, does it show in the web app? It does not show in the web app, only on the Roku app. Both on my Premiere and Express. @@BlazedMonkey Have you looked at the Home Screen setting? Scroll down to your special library and look at "Display in home screen sections such as latest media and continue watching" Don't believe this is a Roku app issue. Yes, I've tried that. As I said in my original post: "I've tried going into Settings -> Home Screen -> and unchecking the box that says "Display in home screen sections such as latest media and continue watching" for that library, but this doesn't actually work, it still shows half watched movies." I didn't see any other place to change that option, and there was nothing like that listed in the Library settings itself. Edited January 21, 2019 by BlazedMonkey
Happy2Play 9811 Posted January 21, 2019 Posted January 21, 2019 (edited) What app version are you on? All libraries I have tested honor that setting, but will test again when I get a chance. Edited January 21, 2019 by Happy2Play
BlazedMonkey 112 Posted January 21, 2019 Author Posted January 21, 2019 FWIW I use Emby on my android phone as well and it doesn't show up there either. Just my Roku's.
BlazedMonkey 112 Posted January 21, 2019 Author Posted January 21, 2019 What app version are you on? All libraries I have tested honor that setting, but will test again when I get a chance. Both my Roku's are running Version 3.0 build 134
BlazedMonkey 112 Posted January 22, 2019 Author Posted January 22, 2019 I don't know if it is relevant or not, but when setting up the library, I chose Content Type: "Home Videos & Photos"
Luke 42241 Posted January 22, 2019 Posted January 22, 2019 @@speechles there's a dedicated resume api the app should switch to.
speechles 2062 Posted January 22, 2019 Posted January 22, 2019 (edited) @@Luke Never knew of this or it would've already been done with the rest of the stuff I am doing. Should I just follow what the web app does? Edited January 22, 2019 by speechles
speechles 2062 Posted January 22, 2019 Posted January 22, 2019 (edited) @@Luke can the /resume be sorted? Or is this like /shows/nextup and done in a fashion that will not sort regardless if it is given sort by/order (aka it comes in one flavor)? Edited January 22, 2019 by speechles
BlazedMonkey 112 Posted January 22, 2019 Author Posted January 22, 2019 Thank you folks for getting on this so fast, I have to say, I'm impressed!
ebr 16334 Posted January 22, 2019 Posted January 22, 2019 @@Luke can the /resume be sorted? Or is this like /shows/nextup and done in a fashion that will not sort regardless if it is given sort by/order (aka it comes in one flavor)? You should just have to change the api handler on line 291. You should be able to leave the sort option as it currently is (datePlayed).
speechles 2062 Posted January 22, 2019 Posted January 22, 2019 (edited) @@ebr but should the user be able to change this order if this was presented on a poster grid screen? The answer on discovery is no. They can't change sort by/order anyways when using "/resume?". So that's how it shall be. Consistency. That ever evolving goal with a moving target finish line. The closer you get, the further the finish line moves away from you. This is the nature of things. Set the bar high. As you approach it. Set it higher. I <3 Emby. <3 <3 <3 sideways icecream cone hearts. I enjoy what we do and these interactions with users. Edited January 22, 2019 by speechles
speechles 2062 Posted February 24, 2019 Posted February 24, 2019 @@BlazedMonkey Are you using the Emby Beta for Roku? Is this still an issue in the Beta? 1
BlazedMonkey 112 Posted February 24, 2019 Author Posted February 24, 2019 @@BlazedMonkey Are you using the Emby Beta for Roku? Is this still an issue in the Beta? As I said earlier in the thread: Both my Roku's are running Version 3.0 build 134 I didn't even know Emby Beta existed. I went ahead an installed Emby Beta from your link, and that seems to have fixed the issue, thank you! Will this be fixed for the regular Emby install at some point in the near future?
BlazedMonkey 112 Posted February 24, 2019 Author Posted February 24, 2019 Thanks for fixing this. Just purchased a 1 year sub for premiere, so we'll see how this goes.
speechles 2062 Posted February 24, 2019 Posted February 24, 2019 (edited) Will this be fixed for the regular Emby install at some point in the near future? Yes. The beta requires no Roku approval/submittal process to complete. It can be self published. The store version must be vetted by Roku which is why it comes after. It should be close to another store release soon. Edited February 24, 2019 by speechles
BlazedMonkey 112 Posted February 24, 2019 Author Posted February 24, 2019 Yes. The beta requires no Roku approval/submittal process to complete. It can be self published. The store version must be vetted by Roku which is why it comes after. It should be close to another store release soon. Excellent, and thank you for the information about beta, that is good to know.
somy 25 Posted May 26, 2021 Posted May 26, 2021 (edited) DELETE found the setting Edited May 26, 2021 by somy
