FrostByte 5453 Posted January 22, 2019 Posted January 22, 2019 If your file has both you can choose the one you want by clicking the [cc] button. Or mark the text based ones default or forced and change your settings so Emby always chooses the one you want There is also an option on the server to convert pgs to text on the fly to avoid transcoding. Look in the Transcoding options on the server toward the bottom There's also a subtitle plugin to search for subs. Other than that I think you would have to convert subs on your own.
phreatic 0 Posted January 22, 2019 Author Posted January 22, 2019 Great, thanks. Sent from my SM-G930F using Tapatalk
Luke 42241 Posted May 28, 2019 Posted May 28, 2019 Emby for Samsung Tizen 1.0.61 has been released for 2015-2019 models. Please try it out and stay tuned to the blog for release notes. Thanks !
af2k 2 Posted July 21, 2019 Posted July 21, 2019 (edited) I can report the same issue(s): 1) On Samsung Tizen (Q7FN 2018 model) subtitles have a black boxed background with an opacity of about 0.7, so its not solid black but a bit transparent, and if no text is to be displayed it has a small squarish box as shown by @@phreatic. (DirectPlay) 2) On the web client subtitles have a full solid black boxed background, and they are located at the bottom edge, no padding whatsoever. (DirectStream) 3) On the iOS (iPhone) client subtitles are shown as expected, with no background (full transparent) and all how it should be. (DirectPlay) The media file is a h264 with SUBRIB (embedded .srt into mkv container) subtitle. All server/client apps are the current official release versions available. Edited July 21, 2019 by af2k 1
FrostByte 5453 Posted July 21, 2019 Posted July 21, 2019 Are you on v.62 USB? I'll try embedded SRT to see if I get that. I don't get this with external SRT files anymore which was fixed in .61 1
af2k 2 Posted July 21, 2019 Posted July 21, 2019 Yes, I'm on v.62 USB. I don't have a external sub (.srt) file right now, I need to test it later with a movie that doesn't have black borders up/down, otherwise you don't see the box
FrostByte 5453 Posted July 21, 2019 Posted July 21, 2019 Okay, I have some episodes of GoT which are full screen and will remux the srt inside the mkv
FrostByte 5453 Posted July 21, 2019 Posted July 21, 2019 (edited) Yes, I can duplicate what af2k sees. Internal SRT has a black box around subs and once it starts the black box never goes away even after the subs are done. @SamES fixed this same issue though with external SRT files somewhere between .29 and .61. External SRT now have a transparent background with a slight outline around letters which you can't see when subs are done. server 4.2.0.30 beta app 1.0.62 USB Edited July 21, 2019 by FrostByte 1
