Luke 42239 Posted June 4, 2019 Posted June 4, 2019 I was able to chase this down. It is resolved for the next release. If you need immediate relief you can install the beta server. Thanks. 1
memc 22 Posted June 8, 2019 Posted June 8, 2019 Tried the beta server but it still didn't help. So I uninstalled and started from scratch again. Trailers worked so there must have been something wrong on my end. On a side note, I noticed everything was still slow even after starting from scratch with the spinning circle and things not loading. Worked out the Cover Art was the cause. Removed the plugin and now everything loads fast
Luke 42239 Posted June 8, 2019 Posted June 8, 2019 Yes cover art will result in additional resource consumption. Thanks.
horstepipe 423 Posted September 19, 2019 Posted September 19, 2019 (edited) @@Luke what's the current state of the sections "New and Upcoming Movies on Dvd & Blu-ray" and "New and Upcoming Movies on Netflix". ? They both only show up outdated movies (2017) without metadata at all. Will you going to fix that or are we supposed to disable those sections in the trailers plugin? Edited September 19, 2019 by horstepipe
Luke 42239 Posted September 19, 2019 Posted September 19, 2019 In my testing they have metadata. What do you mean by no metadata?
horstepipe 423 Posted September 19, 2019 Posted September 19, 2019 In my testing they have metadata. What do you mean by no metadata? forget about this one, metadata is there now. Not sure what went wrong the last time. Thanks
