ffjk 0 Posted January 21, 2019 Posted January 21, 2019 Hi, I really want to switch from plex to emby, but i currently have the following issue: Whenever a file is not on the CloudDrive's local cache & is streamed from the cloud Emby won't play it. (just shows loading circle) I've noticed that it works fine when trandscoding. any idea?
Luke 42216 Posted January 21, 2019 Posted January 21, 2019 Hi there, can you please attach the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
ffjk 0 Posted January 21, 2019 Author Posted January 21, 2019 Hi there, can you please attach the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks ! Sure, thank you! embyserver.txt
Luke 42216 Posted January 21, 2019 Posted January 21, 2019 Hmm, that's quite strange because everything looks normal here. can you provide a copy of the media info from this file from the bottom of the web app detail screen? Thanks !
ffjk 0 Posted January 21, 2019 Author Posted January 21, 2019 Video Title720p H264 CodecH264 Codec tagavc1 AVCYes ProfileHigh Level41 Resolution1280x720 Aspect ratio16:9 AnamorphicNo InterlacedNo Framerate23.976 Bitrate6,602 kbps Colour primariesbt709 Colour spacebt709 Colour transferbt709 Bit depth8 bit Pixel formatyuv420p Ref frames1 NAL4 Audio TitleGer AAC 5.1 Default Languageger CodecAAC Codec tagmp4a ProfileLC Layout5.1 Channels6 ch Bitrate766 kbps Sample rate48,000 Hz DefaultYes Audio TitleEng Dolby Digital 5.1 Languageeng CodecAC3 Codec tagac-3 Layout5.1 Channels6 ch Bitrate640 kbps Sample rate48,000 Hz DefaultNo Containermp4 PathE:\Media\TV\Game of Thrones\Season 2\Game of Thrones - S02E02 - The Night Lands Bluray-720p Proper.mp4 Size3068 MB
Carlo 4561 Posted January 21, 2019 Posted January 21, 2019 Turn on Drive Tracing in Cloud Drive, reboot and try again via Emby. https://stablebit.com/Support/CloudDrive/Manual?Section=Troubleshooting Then take a look at that log file and see if the file is being transferred. Basically you should be able to see the status of the transfer taking place. This will help narrow down where the problem is.
ffjk 0 Posted January 21, 2019 Author Posted January 21, 2019 So you can't direct play any file at all? Just tried using the android tv app, seems to work fine there. Using the web client it rarely works
ffjk 0 Posted January 21, 2019 Author Posted January 21, 2019 Turn on Drive Tracing in Cloud Drive, reboot and try again via Emby. https://stablebit.com/Support/CloudDrive/Manual?Section=Troubleshooting Then take a look at that log file and see if the file is being transferred. Basically you should be able to see the status of the transfer taking place. This will help narrow down where the problem is. Will do. What i've noticed when it doesn't work it starts download/prefetching for sec & then just stops.
Sammy 791 Posted January 21, 2019 Posted January 21, 2019 (edited) Turn on Drive Tracing in Cloud Drive, reboot and try again via Emby. https://stablebit.com/Support/CloudDrive/Manual?Section=Troubleshooting Then take a look at that log file and see if the file is being transferred. Basically you should be able to see the status of the transfer taking place. This will help narrow down where the problem is. I was just going to post " @@cayars ".. Sent from my SM-G960U1 using Tapatalk Edited January 21, 2019 by Sammy 1
ffjk 0 Posted January 22, 2019 Author Posted January 22, 2019 Will do. What i've noticed when it doesn't work it starts download/prefetching for sec & then just stops. I just left the loading emby webclient alone for a few mins and it started playing the file & clouddrive started preteching agian. It starts playing instantly when transcoding video or audio. Also i do not have these issues with plex.
ffjk 0 Posted January 22, 2019 Author Posted January 22, 2019 I just left the loading emby webclient alone for a few mins and it started playing the file & clouddrive started preteching agian. probably doesn't help but here a recording if it behaving this way https://streamable.com/tgo4h
ffjk 0 Posted January 23, 2019 Author Posted January 23, 2019 And it never plays? It does after a few minutes
Luke 42216 Posted January 23, 2019 Posted January 23, 2019 To be that sounds like the data is being altered in some way on the fly that is damaging the video file.
ffjk 0 Posted January 23, 2019 Author Posted January 23, 2019 Hmm.. I don't know its just weird that it works when transcoding. Plays fine with plex.
Carlo 4561 Posted January 23, 2019 Posted January 23, 2019 Web type of file is it? Is it web optimized? Don't worry if you don't know what that means.
ffjk 0 Posted January 23, 2019 Author Posted January 23, 2019 (edited) Web type of file is it? Is it web optimized? Don't worry if you don't know what that means. mp4, but not Web Optimized edit: seems like it's the mp4 files only Edited January 23, 2019 by ffjk
