iBoss 31 Posted February 5, 2019 Author Posted February 5, 2019 (edited) Ok here you go: https://www.dropbox.com/s/9am2hgfcj403j8d/MediaBrowser.Mobile-googlearmv7-release.apk?dl=0 Many thanks .. appreciate your support I have tested it, the character works Now I'll start working on it Edited March 14, 2019 by iBoss
iBoss 31 Posted March 14, 2019 Author Posted March 14, 2019 Finally, I have finished fixing the Arabic font @@Luke please install this font on emby Android mobile and iOS, it will solve all Arabic subtitle issues. Thanks subfont_v1.190314.ttf.zip
Luke 42242 Posted March 14, 2019 Posted March 14, 2019 Ok, in the meantime we made our own edits to the font to support more arabic characters, so now we have to be careful not to step on each other's toes. How does that compare to this: subfont.zip
iBoss 31 Posted March 15, 2019 Author Posted March 15, 2019 (edited) Ok, in the meantime we made our own edits to the font to support more arabic characters, so now we have to be careful not to step on each other's toes. How does that compare to this: Unfortunately, still it has the same issue I'm sure my modification will work I have not only fixed the issue, also I have changed the Arabic font to the better readable for the subtitle. the current one not comfortable for subtitle purpose. to compare between them please see the attached file Edited March 15, 2019 by iBoss
iBoss 31 Posted March 21, 2019 Author Posted March 21, 2019 (edited) Many thanks @@Luke I have just tested emby (beta) android mobile, it's work perfectly. thanks to use my fix. What about iOS and AppleTV? will you use my modification as well? Actually I'm still trying to solve it without using subfont.ttf with mpv support but with no luck (please see this topic that I have started it with mpv support) .. please read it, maybe you can figure it out. Thanks Edited March 21, 2019 by iBoss
Luke 42242 Posted March 21, 2019 Posted March 21, 2019 thanks for the feedback. We're still looking into apple.
Luke 42242 Posted April 4, 2019 Posted April 4, 2019 We'll begin using the custom font with the next updates to the ios and tvos apps. Thanks.
iBoss 31 Posted April 5, 2019 Author Posted April 5, 2019 (edited) I have tried some methods to figure out the issue. Method 01: Download mpv build https://laboratory.stolendata.net/~djinn/mpv_osx/ give me same issue. -------- Method 02: Using Homebrew: brew install freetype brew install fribidi brew install libass brew install ffmpeg install mpv from main source manually https://github.com/mpv-player/mpv/ Same issue ------- Method 03: Configure and compile/install everything manually: git clone https://github.com/source-foundry/freetype2 git clone https://github.com/fribidi/fribidi git clone https://github.com/libass/libass git clone https://github.com/FFmpeg/FFmpeg git clone https://github.com/mpv-player/mpv/ (or from home brew) it works without any issues in Arabic font. So I think the issue from one of these: freetype2, fribidi or libass I hope this can help --------- We'll begin using the custom font with the next updates to the ios and tvos apps. Thanks. In the meantime, I think this is the fastest way to fix it ... Thanks I'm really appreciate your support. I have done some modification on the Arabic font to improve it, could you please use the updated one (attached) on iOS, TVOS and Android Mobile? Thanks subfont_v1.190405.ttf.zip Edited April 5, 2019 by iBoss
Luke 42242 Posted May 3, 2019 Posted May 3, 2019 Emby for iOS 1.7.7 has been released and now uses the custom font file. Thanks. 1
iBoss 31 Posted May 17, 2019 Author Posted May 17, 2019 Emby for iOS 1.7.7 has been released and now uses the custom font file. Thanks. Many Thaaaanks 1
iBoss 31 Posted November 2, 2020 Author Posted November 2, 2020 Hi @Luke The Arabic font I have made is remove from the apps (ios, apple tv and android mobile) and the old issue come again Thanks
Luke 42242 Posted November 2, 2020 Posted November 2, 2020 Hi, what issue is that, missing characters?
iBoss 31 Posted November 2, 2020 Author Posted November 2, 2020 exactly the same issue for this topic please see the attached image from the first post Thanks
iBoss 31 Posted February 27, 2022 Author Posted February 27, 2022 Hi @Luke Thanks, you have fixed the font; there is no issues in characters ... but unfortunately, the font is used is not good also it's not comfortable to read. Kindly I have a favor to ask you, please change the Arabic font to another suitable one that is good for subtitle. also it need some margin at the bottom. My advice is to use "Adobe Arabic Bold" font. Please see the attached screenshot. Thanks
