Oracle 86 Posted January 22, 2019 Posted January 22, 2019 The backup software would keep track or versions, and allow for easier restoration. Imagine you lost 20 movies, would you be able to know exactly which movies to restore? A good piece of software will manage that, for you. I don't recommend using external hard drives. They mostly use crappy desktop drives. Unfortunately, at the present, external WD drives are all I can afford right now. Welcome to being married, I suppose. Haha. For future reference, what would you reccomend? Alright, outstanding. I'll keep that in mind for the future. What are some good softwares?
Guest asrequested Posted January 22, 2019 Posted January 22, 2019 Unfortunately, at the present, external WD drives are all I can afford right now. Welcome to being married, I suppose. Haha. For future reference, what would you reccomend? Alright, outstanding. I'll keep that in mind for the future. What are some good softwares? For the future, a decent NAS. Use the link in post #2 for backup software recommendations.
Oracle 86 Posted January 22, 2019 Posted January 22, 2019 For the future, a decent NAS. Use the link in post #2 for backup software recommendations. Thanks, friend. As usual, you've been a great help. Cheers.
Guest asrequested Posted January 23, 2019 Posted January 23, 2019 (edited) @ went with freefilesync. Works great. I used Syncback pro Edited January 23, 2019 by Doofus 1
