gogreenpower 26 Posted January 20, 2019 Posted January 20, 2019 Hi guys, I know the H series of no longer supported and this latest server update had final broken functionality with the Samsung app, kudos on it lasting so long. Just want to know where I can get the last stable 3.xx version from, not as easy as it looks
gogreenpower 26 Posted January 20, 2019 Author Posted January 20, 2019 FYI, the app still connects, you can navigate to your series/movies but the page it would show with the play button/metadata doesn't appear, you get the side menu show
gogreenpower 26 Posted January 20, 2019 Author Posted January 20, 2019 Hi Luke, On that older so when you sent the cursor all the way to the left when navigating around, a side menu appears with settings and stuff. After some more testing, movies work and the kids login works fine. Just the series under the other login. I will have a look through the settings on the server later. The folder structure is identical between the two and all media is located on the one drive. It's been 3 days since installing v4. Plus I've restarted it. All other apps work fine.
Luke 42216 Posted January 21, 2019 Posted January 21, 2019 Thanks for the info. I think the app might require an update.
