ebr 16313 Posted January 30, 2019 Posted January 30, 2019 So given this, is anyone interested in team working on SQL and posting interesting querys that could benefit others. If so where would be the correct place. Just realize these could break at any time and also potentially damage your database.
xe` 45 Posted January 31, 2019 Author Posted January 31, 2019 I understand that the database is subject to change but I can you explain how querys could damage your database? (I am assuming you mean if you write changes as opposed the query info)?. What would be the correct method to connect a sql client to the Emby dbase: Shutdown Emby and take a copy Take a copy without shutting down Connect client directly to live sql file
ebr 16313 Posted January 31, 2019 Posted January 31, 2019 I understand that the database is subject to change but I can you explain how querys could damage your database? SQL is a powerful language for both querying and updating. You could potentially delete or modify anything that Emby depends on. Shutdown Emby and take a copy Definitely the safest approach. 2
