xenkw0n 2 Posted January 20, 2019 Posted January 20, 2019 If I add any new files to one of my Libraries it will not identify properly and pull down metadata. If I manually identify the files then it works fine. Running Version 4.0.0.2
Luke 42219 Posted January 20, 2019 Posted January 20, 2019 Hi there, can you please go over an example? thanks.
xenkw0n 2 Posted January 20, 2019 Author Posted January 20, 2019 Recently added a movie and it shows up in the Library. The metadata is not identifying properly even after forcing refresh. If I identify it all of the metadata and images get downloaded. Prior to version 4 it would identify as soon as it was added to the library.
bretswinney 22 Posted January 20, 2019 Posted January 20, 2019 I am also seeing this issue Sent from my iPad using Tapatalk
Luke 42219 Posted January 20, 2019 Posted January 20, 2019 Recently added a movie and it shows up in the Library. The metadata is not identifying properly even after forcing refresh. If I identify it all of the metadata and images get downloaded. Prior to version 4 it would identify as soon as it was added to the library. Can you please go over a specific example of a movie? What movie, what exact folder structure? Thanks!
Luke 42219 Posted January 20, 2019 Posted January 20, 2019 I am also seeing this issue Sent from my iPad using Tapatalk Hi there, Can you please go over a specific example of a movie? What movie, what exact folder structure? Thanks! Can you please go over a specific example of a movie? What movie, what exact folder structure? Thanks!
bretswinney 22 Posted January 20, 2019 Posted January 20, 2019 (edited) The Finest Hour Under the movies folder root. The Finest Hour (2018).mp4 Sent from my iPad using Tapatalk Edited January 20, 2019 by bretswinney
Carlo 4561 Posted January 20, 2019 Posted January 20, 2019 What's being described here is NORMAL right after doing the update. The system hasn't finished ALL the things it needs to do in the background to update the current data already in the database. That is why you're not seeing it update this info automatically. However, if you pick on of those movies and manually match it then it does update because you forced it. Just give it time as it may need to run through a couple of nightly tasks before everything gets back to normal. Not saying this is happening to you but essentially your whole system is refreshing data in a short period of time. You could be getting timeouts or throttled by meta-providers which could require Emby to run certain tasks a couple of times (normal daily schedules) before it gets all the data it needs back for you and starts acting the way it did prior to the update. This is where PATIENCE comes in a bit as the Emby server can only do so much if it can't get the data as fast as it wants/needs. It will keep picking up more and more with each run. This took several runs on one of my servers to fully populate everything.
xenkw0n 2 Posted January 20, 2019 Author Posted January 20, 2019 ROOTEMBY\\Media\Movies\First Man 2018 1080p\first.man.2018.proper.1080p.bluray.x264-drones.mkv
Luke 42219 Posted January 20, 2019 Posted January 20, 2019 ROOTEMBY\\Media\Movies\First Man 2018 1080p\first.man.2018.proper.1080p.bluray.x264-drones.mkv @@xenkw0n Can you please attach the emby server log from when this was scanned? thanks.
Luke 42219 Posted January 20, 2019 Posted January 20, 2019 We will be getting an update out to resolve this. I apologize for the disruption.
tillithz 1 Posted January 21, 2019 Posted January 21, 2019 I am seeing this issue as well as most artwork has been removed and a screenshot of the movie is displayed now. I have to identify manually without the year in the name of the movie. is this something that will revert back after update has finished what its doing? if so it seems silly it would remove artwork already matched. can I trigger the system to put back the artwork it found previously instead of screen shots?
Luke 42219 Posted January 21, 2019 Posted January 21, 2019 There is an issue of parsing the movie name and year from the file name. We'll be getting an update out to resolve this. Thanks.
tillithz 1 Posted January 21, 2019 Posted January 21, 2019 any way of getting the metadata from plex?
Luke 42219 Posted January 21, 2019 Posted January 21, 2019 Emby Server 4.0.1 is currently rolling out to address this issue. Thanks guys.
xxAmigoxx 3 Posted July 12, 2019 Posted July 12, 2019 Emby Server 4.0.1 is currently rolling out to address this issue. Thanks guys. I am seeing this for TV series too. Emby cant automatically identify many tv series folder naming => "Marvels.The.Punisher.S02.720p.WEB.X264-Scene" But Emby can't auto identify the show. I have to manually do it. Version 4.1.1.0
Luke 42219 Posted July 12, 2019 Posted July 12, 2019 I am seeing this for TV series too. Emby cant automatically identify many tv series folder naming => "Marvels.The.Punisher.S02.720p.WEB.X264-Scene" But Emby can't auto identify the show. I have to manually do it. Version 4.1.1.0 What is the full folder structure? do you have a series folder for the punisher above that?
Happy2Play 9806 Posted July 12, 2019 Posted July 12, 2019 I am seeing this for TV series too. Emby cant automatically identify many tv series folder naming => "Marvels.The.Punisher.S02.720p.WEB.X264-Scene" But Emby can't auto identify the show. I have to manually do it. Version 4.1.1.0 That would be a season folder not a series folder. Anything outside the supported naming scheme/structure is bound to fail and require manual intervention. https://github.com/MediaBrowser/Wiki/wiki/TV-naming
Luke 42219 Posted July 12, 2019 Posted July 12, 2019 That would be a season folder not a series folder. Anything outside the supported naming scheme/structure is bound to fail and require manual intervention. https://github.com/MediaBrowser/Wiki/wiki/TV-naming Yup, that's where I was going Thanks.
xxAmigoxx 3 Posted August 3, 2019 Posted August 3, 2019 What is the full folder structure? do you have a series folder for the punisher above that? No i dont. its the only folder.
Luke 42219 Posted August 3, 2019 Posted August 3, 2019 No i dont. its the only folder. Currently we require series folders. We'd like to support what you're doing in the future, but we're not there yet.
xxAmigoxx 3 Posted August 3, 2019 Posted August 3, 2019 That would be a season folder not a series folder. Anything outside the supported naming scheme/structure is bound to fail and require manual intervention. https://github.com/MediaBrowser/Wiki/wiki/TV-naming Okay then, may be its a feature request, to Identify season Though it is not in a Series folder and merge all the seasons Into one series
