playloud 10 Posted January 20, 2019 Posted January 20, 2019 Roku TV 3.0.134 All my special feature files are stored in a folder called "Extras" within each movie folder. They are no longer visible in the Roku app. They ARE visible in the Web App.
ebr 16335 Posted January 20, 2019 Posted January 20, 2019 Not sure it will make a difference but you should update the app.
playloud 10 Posted January 21, 2019 Author Posted January 21, 2019 Current version says 3.0.128 I'm on 3.0.134.... Tried the Beta v3.0.136 (I think). No change. Emby for RokuStable: v3.0.128Beta: v3.0.133 (2019/01/03)
Happy2Play 9811 Posted January 21, 2019 Posted January 21, 2019 (edited) That page is behind on current versions for Emby for Roku. I believe current Stable is 3.0.134 and beta is 3.0.136. @@CBers @playloud Where extras ever visible? Edited January 21, 2019 by Happy2Play 1
nappysolo 6 Posted January 22, 2019 Posted January 22, 2019 Same problem here. Has always worked fine. Worked the last time I tried a few days ago. Now, it doesn't show any extras. I've tried both stable (134) and beta (136).
Luke 42242 Posted January 22, 2019 Posted January 22, 2019 @@speechles, what you would do is just make the call to get the extras rather than checking HasSpecials. Then make sure the app handles 0 results appropriately by hiding the section.
speechles 2062 Posted January 22, 2019 Posted January 22, 2019 (edited) @@speechles, what you would do is just make the call to get the extras rather than checking HasSpecials. Then make sure the app handles 0 results appropriately by hiding the section. Can do. ( fix: Don't check just get #198 ) Edited January 22, 2019 by speechles
playloud 10 Posted January 23, 2019 Author Posted January 23, 2019 @@Happy2Play - Yes, the extras have always been visible until now. On the movie page, you scroll down past scene thumbnails, and any files in the Extras folder are visible, scrolling across.
Luke 42242 Posted January 23, 2019 Posted January 23, 2019 @@playloud we're working on resolving this. Thanks !
nappysolo 6 Posted January 26, 2019 Posted January 26, 2019 (edited) Beta 138 works great! Thanks for the quick turnaround. Edited January 26, 2019 by nappysolo
playloud 10 Posted January 28, 2019 Author Posted January 28, 2019 Beta 138 has restored the ability to see files in the "Extras" folders, though they do not have scene image thumbnails. Maybe these will populate later? However the main issue I have seen is sorting preferences are not saved after each use, namely "group into collections".
